Hosted domain connection refused - help...
elcopdoo
Basic Pleskian
We have latest Plesk 12 on Centos 7,
I can login to Plesk UI and mail is working,
but cannot access hosted website www.elcop.hr :
Error: Connection refused
Anyone can help?
Make sure that port 80 is not firewalled there. I have checked accessibility of this port and I see:
# telnet elcop.hr 80
Trying 92.242.243.163...
telnet: connect to address 92.242.243.163: Connection refused
I disabled firewalld and selinux, what can I do next?
Is this correct IP address for this domain - 92.242.243.163 ?
Have you checked Apache logs? Can you connect to port 80 of this domain directly on this Plesk server?
IP is correct,
[root@server2 ~]# telnet elcop.hr 80
Seems that port 80 is blocked but with what?
I tried to disable failban and Plesk firewall with no luck...
What about output of command
# lsof -i tcp:80
on this Plesk server. Are you sure that Apache is up and running?
Check that Apache is really started:
# /etc/init.d/httpd status
httpd (pid 26544) is running...
[root@server2 ~]# sudo systemctl enable httpd.service
[root@server2 ~]# sudo systemctl start httpd.service
[root@server2 ~]# lsof -i tcp:80
[root@server2 ~]# systemctl is-active httpd.service
active
[root@server2 ~]# sudo systemctl restart httpd.service
After reboot issue remains...
I know which ports, I need procedure for opening ports in Centos 7 minimal...
I tried with:
SELINUX=disabled
and
firewall-cmd --zone=dmz --add-port=xx/tcp --permanent
firewall-cmd --reload
I cannot login to Plesk...
If I turn off firewalld completely, does Plesk replace with it's own firewall?
Unfortunately, problem reappeared after few hours:
Connection refused
This time opening ports is not helping:
# firewall-cmd --zone=public --add-port=80/tcp --permanent
# firewall-cmd --reload
I can login to Plesk GUI and mail works, but domain site and webmail not (Connection refused).
I completely reinstalled Centos 7 and Plesk and all worked till now...
Is this a problem in Plesk?
I noticed that after fresh installation Plesk dont give option to update to last MU 13.
Update:
1. Restarted NGINX
2. Restarted APACHE
Access to website now works..
Seems that NGINX and/or APACHE get stuck at some point...
Still no way to update to MU 13...
Here is the part of the Plesk panel log:
[18-Aug-2014 18:25:58 Europe/Berlin] PHP Fatal error: Uncaught exception 'Servi
ce_Driver_Exception' with message 'Can not reload proxy server: ' in /usr/local/
psa/admin/plib/Service/Driver/Web/Proxy/Nginx.php:116
Stack trace:
#0 /usr/local/psa/admin/plib/Template/Writer/Webserver/Abstract.php(86): Service
_Driver_Web_Proxy_Nginx->restart()
#1 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(212): Template_W
riter_Webserver_Abstract->restart()
#2 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(112): Template_C
onfiguration_Applier->_applyConfigurationsToServiceNode(1, Array)
#3 [internal function]: Template_Configuration_Applier->applyConfiguration()
#4 {main}
thrown in /usr/local/psa/admin/plib/Service/Driver/Web/Proxy/Nginx.php on line
116
#4 /usr/local/psa/admin/plib/Template/Writer/Webserver/Abstract.php(86): Service_Driver_Web_Proxy_
Nginx->restart()
#5 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(212): Template_Writer_Webserver_Ab
stract->restart()
#6 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(112): Template_Configuration_Appli
#7 [internal function]: Template_Configuration_Applier->applyConfiguration()
#8 {main}
[18-Aug-2014 18:25:58 Europe/Berlin] PHP Fatal error: Uncaught exception 'Service_Driver_Exceptio
n' with message 'Can not reload proxy server: ' in /usr/local/psa/admin/plib/Service/Driver/Web/Pr
oxy/Nginx.php:116
Stack trace:
#0 /usr/local/psa/admin/plib/Template/Writer/Webserver/Abstract.php(86): Service_Driver_Web_Proxy_
Nginx->restart()
#1 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(212): Template_Writer_Webserver_Ab
stract->restart()
#2 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(112): Template_Configuration_Appli
#4 {main}
thrown in /usr/local/psa/admin/plib/Service/Driver/Web/Proxy/Nginx.php on line 116
#4 /usr/local/psa/admin/plib/Template/Writer/Webserver/Abstract.php(86): Service_Driver_Web_Proxy_Nginx->restart()
#5 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(212): Template_Writer_Webserver_Abstract->restart()
#6 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(112): Template_Configuration_Applier->_applyConfigurat
#8 {main}
[18-Aug-2014 18:25:58 Europe/Berlin] PHP Fatal error: Uncaught exception 'Service_Driver_Exception' with message 'Can
not reload proxy server: ' in /usr/local/psa/admin/plib/Service/Driver/Web/Proxy/Nginx.php:116
Stack trace:
#0 /usr/local/psa/admin/plib/Template/Writer/Webserver/Abstract.php(86): Service_Driver_Web_Proxy_Nginx->restart()
#1 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(212): Template_Writer_Webserver_Abstract->restart()
#2 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(112): Template_Configuration_Applier->_applyConfigurat
#4 {main}
After few more hours NGINX get stuck again,
I get 504 Timeout error.
Please give instructions how to find the root of this instability...
What is this:
'Cannot reload proxy server: ' in /usr/local/psa/admin/plib/Service/Driver/Web/Proxy/Nginx.php:116
Update:
hapened twice today
after server restart domain is not accessible until I restart NGINX and APACHE..
NGINX restart solved the problem
I had the same problem as above. After i restarted the NGINX module website was online again. One obvious thing that i mentioned is that not all of the webpages were offline.
Strange error but solved :)
I have the same issue!
Fresh CentOS 7 install and newest plesk 12.
When I reboot the server, ports 80, 433 not responsive! I need to restart nginx module or disabled it! This is cleary a Plesk Bug and should be resolved ASAP!
