X
Xandarth
After updating to Plesk 7.6 all of our servers have the same mysterious problems. Both are mail-related, but they don't seem to be related to eachother...
1st issue:
We're using Horde Webmail. Since the update it sometimes happens that when logging into Horde using IMAP, you can't see all the mails in your inbox or in other folders. Sometimes you see 3 mails when there should be 20, sometimes you can't see any mails at all. But physically they are definately there, Horde just can't see them.
It works fine when using the POP3 method for Webmail, but we'd like to have IMAP so that the user is able to create his own folders and have a sent mail folder. A reboot sometimes solves the problem, but not always. Deleting the index.xml file in the mailbox folder only helps at the first encounter of the problem for every mailbox, but afterwards it's just as useless as rebooting. Also the mchk.exe repair thingy only helped sometimes too... i completely failed to detect any kind of pattern in this behaviour, the problem seems totally random... the event viewer didn't show any signs of problems either (as usual)...
2nd issue (maybe even stranger than the first one):
At least this is a general problem that affects all mailboxes at the same time, but that doesn't make it any less strange. From time to time (about 3-5 times a week) the mailserver just stops delivering messages. He accepts them and the log entry in the SMTP log is complete and there are no sings of an error, but the mail never reaches the mailbox of the designated user. The mails don't hang in the incoming queue nor can i seem to find them anywhere else. After a simple reboot however, all of thise previously missing mails get delivered to the correct mailboxes. As with the other problem mentioned above, the event viewer doesn't show anything and none of the maillogs show any missing entries/problems/warnings or whatever.
If anyone has only the slightest idea what the cause of any of those problems could be, please inform me. Any kind of help would be greatly appreciated as I am already out of ideas and of course the customers are starting to complain a lot about those mail issues
1st issue:
