1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
  2. Dear Pleskians, please read this carefully! New attachments and other rules Thank you!
    Dismiss Notice
A few 7.5.1 problems ...
Discussion in 'Plesk for Linux - 8.x and Older' started by lvalics, Jan 8, 2005.
  1. lvalics
    lvalics Silver Pleskian Plesk Guru
    36
    43%
    Jun 20, 2003
    962
    31
    Romania
    After some time, I observed some anomalies on PLESK 7.5.1.
    I create a DB and after I wanna see in PLESK phpMyAdmin, I get:
    SHOW DATABASES LIKE 'testdb'
    MySQL said: Documentation
    #1227 - Access denied. You need the SHOW DATABASES privilege for this operation
    It was created with PLESK so is strange.
    Only thing is that is MySQL 4.
    If I delete and recreate, than will be ok :-(
    An another sad thing is when I try to delete domain or create sometimes is stuck PLESK and nothing will happen and I cannot do anything until I not restart the server (or prbabbly some process need to be killed, but I cannot kill psaservmng ...
    Any ideea?
  2. lvalics
    36
    43%
    Jun 20, 2003
    962
    31
    Romania
    For first problem I find the solution, database name was wih _ underscore and even if PLESK accepted, not worked. So not use databas_like_this ...
  3. JLChafardet
    JLChafardet Regular Pleskian
    26
    57%
    Feb 20, 2004
    379
    Caracas - Venezuela
    Adding this to:
    /usr/local/psa/admin/htdocs/domains/databases/phpMyAdmin/config.inc.php
    solves the issue.
    $db_name = str_replace("_","\_", $db_name);
    cd /usr/local/psa/admin/htdocs/domains/databases/phpMyAdmin
    vi config.inc.php
    /You can disable
    Press I down the line that says
    // You can disable a server config entry by setting host to ''.
    and paste that line.
    save and exit.
    problem solved :)
Loading...
