U
user1599
My Apache Server Keeps crashing several times a day and these are the errors:
[Wed Apr 16 09:19:34 2008] [notice] caught SIGTERM, shutting down
[Wed Apr 16 09:19:36 2008] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Apr 16 09:19:36 2008] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Wed Apr 16 09:19:36 2008] [warn] Init: SSL server IP/port conflict: default-69-41-165-210:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:78) vs. webmail:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:133)
[Wed Apr 16 09:19:36 2008] [warn] Init: SSL server IP/port conflict: server.atrl.net:443 (/var/www/vhosts/atrl.net/conf/httpd.include:152) vs. webmail:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:133)
[Wed Apr 16 09:19:36 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Apr 16 09:19:36 2008] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 16 09:19:36 2008] [notice] Digest: done
[Wed Apr 16 09:19:37 2008] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Wed Apr 16 09:19:37 2008] [warn] Init: SSL server IP/port conflict: default-69-41-165-210:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:78) vs. webmail:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:133)
[Wed Apr 16 09:19:37 2008] [warn] Init: SSL server IP/port conflict: server.atrl.net:443 (/var/www/vhosts/atrl.net/conf/httpd.include:152) vs. webmail:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:133)
[Wed Apr 16 09:19:37 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Apr 16 09:19:37 2008] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Wed Apr 16 09:19:46 2008] [emerg] (43)Identifier removed: couldn't grab the accept mutex
[Wed Apr 16 09:19:46 2008] [emerg] (22)Invalid argument: couldn't release the accept mutex
[Wed Apr 16 09:19:46 2008] [emerg] (22)Invalid argument: couldn't grab the accept mutex
[Wed Apr 16 09:19:47 2008] [alert] Child 27219 returned a Fatal error... Apache is exiting!
[Wed Apr 16 09:24:37 2008] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Apr 16 09:24:37 2008] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Wed Apr 16 09:24:37 2008] [warn] Init: SSL server IP/port conflict: default-69-41-165-210:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:78) vs. webmail:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:133)
[Wed Apr 16 09:24:37 2008] [warn] Init: SSL server IP/port conflict: server.atrl.net:443 (/var/www/vhosts/atrl.net/conf/httpd.include:152) vs. webmail:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:133)
[Wed Apr 16 09:24:37 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Apr 16 09:24:37 2008] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 16 09:24:37 2008] [notice] Digest: done
[Wed Apr 16 09:24:38 2008] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Wed Apr 16 09:24:38 2008] [warn] Init: SSL server IP/port conflict: default-69-41-165-210:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:78) vs. webmail:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:133)
[Wed Apr 16 09:24:38 2008] [warn] Init: SSL server IP/port conflict: server.atrl.net:443 (/var/www/vhosts/atrl.net/conf/httpd.include:152) vs. webmail:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:133)
[Wed Apr 16 09:24:38 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Apr 16 09:24:38 2008] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
What can I do to fix this what is causing it?
