O
onaweb
Hello,
I am running PSA 6.5.2 on W2K3 Web Edition.
I just set up a new client with a SSL cert (first site using an SSL cert) so it is set up on its own IP. All other sites using asp are just fine, but this one for some reason comes up 500. I've checked all the permissions and everything is the same as the other sites. I have also done the enable parent thing and search for the synciwam.vbs file, but it doesn't seem to work. All other sites on the server are not having any problems with asp but just this one. This one is the only site on that IP.
We have even tried a simple asp test page, but still gives up the 500 Internal Server Error.
