A
Adam1234
Having problem during autinstallation process of plesk 8.1.0.
- psa_installer_v3.1.0_build061201.02_os_RedHat_el4_i386
- psa-8.1.0-rhel4.build81070224.19.i586.rpm.tar.gz
Here is the following Linux environment before PLESK installation:
Red Hat Enterprise Linux ES (v. 4 for 32-bit x86)
PHP 5.1.6
mysql Ver 14.12 Distrib 5.0.27
Here is the following problem with MySQL in autoinstaller log file
===> Installing rbash
Checking that /bin/rbash registered as login shell...
/bin/rbash
/bin/rbash is already registered as login shell
/var/tmp/rpm-tmp.4939: line 11044: /etc/init.d/mysqld: No such file or directory
Trying to start MySQL server... /var/tmp/rpm-tmp.4939: line 10890: /etc/init.d/mysqld: No such file or directory
ERROR while trying to start MySQL server
Aborting...
STOP psa-8.1.0-rhel4.build81061129.22 installing AT Sun Mar 25 05:41:20 IST 2007
MySQL 5.0.27 is started and root password Null
Auto installation is trying to start mysqld again from
/etc/init.d/mysqld which in fact is running from
/usr/sbin/mysqld
Where I can force or do changes to point autoinstaller to right MySQL path - if this is the case ?
Also during the installation I noticed some warnings:
package MySQL-devel-standard-5.0.27-0.rhel4.i386 conflict with package mysql-4.1.20-1.RHEL4.1.i386
packages conflict by files detected: package MySQL-devel-standard-5.0.27-0.rhel4.i386 conflict with package mysql-devel-4.1.20-1.RHEL4.1.i386
package MySQL-server-standard-5.0.27-0.rhel4.i386 conflict with package mysql-4.1.20-1.RHEL4.1.i386
package MySQL-server-standard-5.0.27-0.rhel4.i386 conflict with package mysql-server-4.1.20-1.RHEL4.1.i386
packages conflict by files detected: package krb5-devel-1.3.4-33.i386 conflict with package krb5-server-1.3.4-27.i386
packages conflict by files detected: package php-pear-1:1.4.9-1.2.centos.noarch conflict with package php-4.3.9-3.18.i386
packages conflict by files detected: package MySQL-client-standard-5.0.27-0.rhel4.i386 conflict with package mysql-4.1.20-1.RHEL4.1.i386
packages conflict by files detected: package python-2.3.4-14.3.i386 conflict with package python-devel-2.3.4-14.2.i386
MySQL 5.0.27 and php 5.1.6 are not distrubuted via RHN channels so they were installed separately before Plesk installation.
Did any of you come across with the same problem ?
PHP 5.1.6
/bin/rbash
Aborting...
/usr/sbin/mysqld
