Hi all,
We have developed a small script (for our use but why not share it?).
This script with a help of other great script (AutoMySQLBackup) will backup all MySQL databases (dump it) then also will archive some directories and then connect to a remote FTP server and upload it.
Some of you will say ... PLESK 8 have some tools for backup and even remote FTP.
Indeed. Our solution is different in some way.
1. Will dump daily the databases (based on AutoMySQLBackup shell script)
2. Will arhive directories what you define (we use usually /etc/ and /var/www/vhosts/*/).
3. Have GPG encryption. (switch ON/OFF)
4. Will upload to remote FTP, weekly (or can daily)
5. Will send mail to ADMIN about job.
6. Will report from remote FTP all files for disk space usage and will also delete files from there.
7. Can restore file from Remote FTP.
8. More small settings.
You can download the files from
http://www.web-hosting-control-panel-addons.com/binaries/gfx_backup/gfx_backup
You need to setup this file like in file comments.
Then also download
http://www.web-hosting-control-panel-addons.com/binaries/gfx_backup/gfx_backup_cron
This will be need to copy into /etc/cron.weekly (daily)
Also you can get from http://sourceforge.net/projects/automysqlbackup/
the MySQL Backup and setup.
Any other ideea are welcome.
Hope will help.
Then also download
Hope will help.
