M
manarak
I tried to upgrade my PSA 7.5.3 from ART to 7.5.4 through the updater.
The upgrade gave some errors:
At this time, the errors in the Plesk panel began:
And I could not upgrade.
I then removed spamassassin through yum remove spamassassin.
Then I tried upgrading PSA to 7.5.4 through the updater.
Since then, I cannot login anymore to the control panel, the error message always says:
Can anyone help me getting these problems solved?
-> restore access to admin panel
-> upgrade Plesk to 7.5.4 proper?
Thank you
Preparing for packages installation...
----- begin of output -----
Installing /PSA_7.5.3/rpm_FedoraCore_2/opt/mail/perl-Text-Iconv-1.2-21.i586.rpm
Installing /PSA_7.5.3/rpm_FedoraCore_2/opt/mail/psa-spamassassin-7.5.3-fc2.build75050506.13.i586.rpm
error: Failed dependencies:
psa-spamassassin conflicts with spamassassin-3.1.0-1.rhfc2.art
----- end of output -----
===> Autoinstaller: stopped logging at Sun Oct 16 09:59:54 2005
The file loger.php3 is part of Plesk distribution. It cannot be run outside of Plesk environment.
The file constants.php3 is part of Plesk distribution. It cannot be run outside of Plesk environment.
Thank you
