1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
cdonts problem
Discussion in 'Plesk for Windows - 8.x and Older' started by Jerry80, Nov 7, 2004.
  1. Jerry80
    Jerry80 Guest
    i need to use a formmail using cdonts so i installed and registred the dll.
    The problem is that i get a 'permission error'
    Probably i've to modify something into mailroot directory....but how exactly? Anybody had same problems?
  2. Deltafox
    Deltafox Guest
    i have exactly same problem..
    if you change permissions on C:\Inetpub\mailroot\........add user everybody and give read & write permission.........your script seems to work.
    but mail stays in dir C:\Inetpub\mailroot\Pickup folder :(
  3. bmorejon
    bmorejon Guest
    Which is your OS ?
  4. Jerry80
    Jerry80 Guest
    win2003 web edition
  5. bmorejon
    bmorejon Guest
    Win2003 Editions don't work anymore with CDONTS
    Now you should use CDSYS
  6. Jerry80
    Jerry80 Guest
    But i read that you can install the cdonts dll .... :-/
  7. bmorejon
    bmorejon Guest
  8. Deltafox
    Deltafox Guest
  9. AbsolutelyFreeW
    AbsolutelyFreeW Guest
    do you have a hhowto for cdosys to?
  10. maarten
    maarten Guest
    try www.dimac.net jmail component is working fine.
    If you use iis smtp server you can also connect to port 8025 instead.
  11. AbsolutelyFreeW
    you may also want to use blat.. works good at least with formmail.pl
  12. Deltafox
    Deltafox Guest
    this works for me:
    PHP:
    Set iConf CreateObject("CDO.Configuration")
    Set Flds iConf.Fields
    Flds
    ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "localhost"
    Flds("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
    Flds
    ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
    Flds
    .Update
    Set myMail
    CreateObject("CDO.Message")
    myMail.Configuration iConf
    myMail
    .From
    myMail.To
    enz
    default server configuration is using pickup folder, does anybody know how to change this? (because my pickup folder doesn't work)
Loading...
