    CentOS2Alma discussion
CPU resources jump with mysql 4? Help!
G
goosemoose
I finally got my host to upgrade mysql to version 4 and now my cpu resource have jumped in plesk from 50-60% on avg to 90-100% on average. My privvmpages is also hovering around 48k rather than the 38k it was before the update.
Does anyone know why this is happening, or how to fix it? It's causing a huge slow down in my forum because of the lack of resources.
Thanks
Maybe this will help someone help me. here is a top while my site basically becomes nonresponsive.
[root@login mytop]# top
20:35:02 up 4:14, 1 user, load average: 0.13, 0.54, 0.70
20:35:07 up 4:14, 1 user, load average: 0.12, 0.53, 0.69
20:35:12 up 4:14, 1 user, load average: 0.11, 0.52, 0.69
20:35:17 up 4:14, 1 user, load average: 0.10, 0.51, 0.68
20:35:22 up 4:14, 1 user, load average: 0.09, 0.50, 0.68
20:35:27 up 4:14, 1 user, load average: 0.08, 0.49, 0.68
20:35:32 up 4:14, 1 user, load average: 0.08, 0.49, 0.67
20:35:37 up 4:14, 1 user, load average: 0.07, 0.48, 0.67
20:35:42 up 4:14, 1 user, load average: 0.07, 0.47, 0.66
20:35:47 up 4:15, 1 user, load average: 0.06, 0.46, 0.66
20:35:52 up 4:15, 1 user, load average: 0.06, 0.45, 0.66
20:35:57 up 4:15, 1 user, load average: 0.05, 0.45, 0.65
20:36:02 up 4:15, 1 user, load average: 0.05, 0.44, 0.65
20:36:07 up 4:15, 1 user, load average: 0.04, 0.43, 0.64
20:36:12 up 4:15, 1 user, load average: 0.04, 0.42, 0.64
20:36:17 up 4:15, 1 user, load average: 0.04, 0.42, 0.64
20:36:22 up 4:15, 1 user, load average: 0.03, 0.41, 0.63
20:36:27 up 4:15, 1 user, load average: 0.03, 0.40, 0.63
20:36:32 up 4:15, 1 user, load average: 0.03, 0.40, 0.63
20:36:37 up 4:15, 1 user, load average: 0.02, 0.39, 0.62
20:36:42 up 4:15, 1 user, load average: 0.02, 0.38, 0.62
20:36:47 up 4:16, 1 user, load average: 0.02, 0.38, 0.62
20:36:52 up 4:16, 1 user, load average: 0.02, 0.37, 0.61
20:36:57 up 4:16, 1 user, load average: 0.02, 0.36, 0.61
20:37:02 up 4:16, 1 user, load average: 0.02, 0.36, 0.61
20:37:07 up 4:16, 1 user, load average: 0.01, 0.35, 0.60
20:37:12 up 4:16, 1 user, load average: 0.01, 0.34, 0.60
20:37:17 up 4:16, 1 user, load average: 0.01, 0.34, 0.60
20:37:23 up 4:16, 1 user, load average: 0.01, 0.33, 0.59
20:37:28 up 4:16, 1 user, load average: 0.01, 0.33, 0.59
20:37:33 up 4:16, 1 user, load average: 0.01, 0.32, 0.59
20:37:38 up 4:16, 1 user, load average: 0.01, 0.32, 0.58
20:37:43 up 4:16, 1 user, load average: 0.01, 0.31, 0.58
20:37:48 up 4:17, 1 user, load average: 0.01, 0.30, 0.58
20:37:53 up 4:17, 1 user, load average: 0.08, 0.32, 0.58
20:37:58 up 4:17, 1 user, load average: 0.08, 0.31, 0.57
20:38:03 up 4:17, 1 user, load average: 0.07, 0.31, 0.57
20:38:08 up 4:17, 1 user, load average: 0.07, 0.30, 0.57
20:38:13 up 4:17, 1 user, load average: 0.06, 0.29, 0.56
20:38:18 up 4:17, 1 user, load average: 0.06, 0.29, 0.56
20:38:23 up 4:17, 1 user, load average: 0.05, 0.28, 0.56
20:38:28 up 4:17, 1 user, load average: 0.05, 0.28, 0.55
45 processes: 44 sleeping, 1 running, 0 zombie, 0 stopped
CPU states: cpu user nice system irq softirq iowait idle
total 0.0% 0.0% 0.4% 0.0% 0.0% 0.0% 399.2%
cpu00 0.0% 0.0% 0.0% 0.0% 0.0% 0.0% 100.0%
cpu01 0.0% 0.0% 0.0% 0.0% 0.0% 0.0% 100.0%
cpu02 0.0% 0.0% 0.5% 0.0% 0.0% 0.0% 99.4%
cpu03 0.0% 0.0% 0.0% 0.0% 0.0% 0.0% 100.0%
Mem: 8275180k av, 7649348k used, 625832k free, 0k shrd, 1586420k buff
3043592k active, 3739952k inactive
Swap: 16386292k av, 20436k used, 16365856k free 2100576k cached
PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME CPU COMMAND
7953 root 15 0 1040 1040 740 R 0.5 0.0 0:01 2 top
1 root 8 0 460 460 412 S 0.0 0.0 0:00 2 init
9472 root 9 0 544 544 468 S 0.0 0.0 0:01 1 syslogd
9501 root 9 0 1524 1524 1388 S 0.0 0.0 0:00 2 sshd
9635 root 8 0 836 836 704 S 0.0 0.0 0:00 3 xinetd
9653 root 9 0 1016 1016 876 S 0.0 0.0 0:00 2 safe_mysqld
9737 mysql 9 0 28868 28M 3352 S 0.0 0.3 0:14 3 mysqld
9969 root 9 0 21004 20M 2408 S 0.0 0.2 0:00 2 spamd
10124 root 9 0 10524 10M 9888 S 0.0 0.1 1:26 3 httpd
10503 root 9 0 4928 4924 4760 S 0.0 0.0 0:01 2 httpsd
10543 root 9 0 576 576 508 S 0.0 0.0 0:00 1 crond
and here is a mytop
MySQL on localhost (4.0.23a) up 0+04:29:31 [20:50:27]
Queries: 204.1k qps: 13 Slow: 20.0 Se/In/Up/De(%): 74/04/08/05
Cache Hits: 115.3k Hits/s: 7.3 Hits now: 0.0 Ratio: 75.9% Ratio now: 0.0%
Key Efficiency: 95.6% Bps in/out: 2.0k/21.5k
Id User Host/IP DB Time Cmd Query or State
6083 dmaricic localhost goosemoose 0 Query show full process
6082 dmaricic localhost goosemoose 1 Query DELETE FROM mos_s
6081 dmaricic localhost goosemoose 5 Query DELETE FROM mos_s
6079 dmaricic localhost goosemoose 7 Query UPDATE mos_sessio
6080 dmaricic localhost goosemoose 7 Query DELETE FROM mos_s
I have the same problem.
As I investigated PSA is causing the problem.
If you turn it off and comment all cronjobs - mysql will be going fine
