B
BrunoV
Hello
I am running PLESK 9.2.2 under Centos 5.3 32 bits
I am trying to upgrade this server to 9.2.3 (It worked fine onto another servers)
Below the logs:
Starting installation of packages
Installing the package psa-migration-manager-9.2.3-cos5.build92091016.19.i586, psa-backup-manager-9.2.3-cos5.build92091016.19.i586, psa-api-rpc-9.2.3-cos5.build92091016.19.noarch, psa-9.2.3-cos5.build92091016.19.i586, psa-api-9.2.3-cos5.build92091016.19.noarch, plesk-skins-9.2.3-0.285063.noarch, psa-updates-9.2.3-cos5.build92091210.17.noarch, psa-appvault-updates-9.2.3-cos5.build92091016.19.noarch, psa-hotfix3-9.2.3-9.2.3-cos5.build92091210.17.i586
Préparation des paquetages pour l'installation...
paquetage psa-api-9.2.3-cos5.build92091016.19.noarch déjà installé
paquetage plesk-skins-9.2.3-0.285063.noarch déjà installé
paquetage psa-9.2.3-cos5.build92091016.19.i586 déjà installé
paquetage psa-api-rpc-9.2.3-cos5.build92091016.19.noarch déjà installé
ERROR: Unable to install the requested packages because either there is
not enough free disk space left, or there are package dependency problems.
Warning! Not all packages were installed.
Please check if your system services are operable.
Please, contact product technical support.
Free disk space is enough (about 10 GB) so it is a dependency problem but the packages are not provided, so I don't know how to fix this.
I tried with the GUI, the autoinstaller tool, with the base packages, and so on. But I still have this error.
Many packages are now installed, but the base package is still 9.2.2
With autoinstaller there is the following option: --debug
Where this log is wrote ?
Some help will be appreciated ;-)
Below the logs:
