A
Alojaliko
Hi, I finally got upgraded my plesk to 7.5, but now I have a dual installation of psa-7.1.7 and psa-7.5.4. This is how it looks:
[root@plesk root]# rpm -q psa
psa-7.1.7-rhel3.build71050228.12
psa-7.5.4-rhel3.build75050824.12
This problem is causing the psarestore function to fail:
[root@plesk root]# /usr/local/psa/bin/psarestore -t -m map_file -s shells_map_file -f /old/BK/dump.aa -
You are running PSA version 7.1.7 . This script will work properly with PSA versions 7.5.0 - 7.5.x only.
And my httpd process is not working. I've tried to restart it using the panel but it wont start. I tried SSH and it says [OK] but then it does not appear in the process list. When I try to stop it, it fails:
[root@plesk /]# /etc/init.d/httpd start
Starting httpd: [ OK ]
[root@plesk /]# /etc/init.d/httpd stop
Stopping httpd: [FAILED]
Anyone has experienced this kind of trouble?
Thanks a lot.
Thanks a lot.
