W
whryzak
I have local a Windows PC and a Unix PC with Suse 10 and Plesk 8 1-user and on the Web a Suse 10 with 30 userPlesk8.
FTP between local PC and also between Windows and Web Suse works, but not from local Linux to remote Linux:
Local Windows (LEAPFTP) to local Suse : OK
Local Suse (IglooFTP) to Windows : OK
Local Suse (IglooFTP) to another local Suse: OK
Local Windows (LEAPFTP) to Web Suse: OK
Local Suse (with all programs) to Web Suse: Errors:
Connection works, and Password is accepted, but directory of remote Unix is not shown, and following errors come:
Entering passive Mode
Timeout (socket connect)
Unable to connect socket
Unable to connect to data socket
Unable to bind data socket
Unable to get host reply
List command failed
When I disable the firewall on local unix its the same
Some suggestions ?
List command failed
Some suggestions ?
