    CentOS2Alma discussion
FTP trouble
E
Egenius
Hi !
I'm install Plesk 8.6.0.4 on OpenVZ virtual machine under Centos 5.2.
I have trouble with FTP connect on server. When I connect from TotalCommander I see empty page.
In logs on server I see this message:
proftpd: Deprecated pam_stack module called from service "proftpd"
proftpd: pam_env(proftpd:setcred): Unable to open config file: /etc/security/pam_env.conf: No such file or directory
proftpd: pam_succeed_if(proftpd:session): error retrieving information about user 0
But this file is present with permitions 644.
I try connect to active and passive mode, and get no effect.
How I can solve this problem ?
Thank's !
Oh yes!
I solved the problem. It was only a point in the config ProFTPD range of passive ports and open access to firewall.
Why?
Hi all
I detected the same problems in a fresh Plesk 9.2 installation on the logs messages and secure:
# cat /var/log/secure |grep proftpd
Jul 23 11:06:12 249115 proftpd: Deprecated pam_stack module called from service "proftpd"
Jul 23 11:06:12 249115 proftpd: pam_env(proftpd:setcred): Unable to open config file: /etc/security/pam_env.conf: No such file or directory
I fixed removing the /etc/pam.d/proftd and making new one with
# cat ftp
#%PAM-1.0
auth required /lib/security/pam_listfile.so item=user sense=deny file=/etc/ftpusers onerr=succeed
auth required /lib/security/pam_pwdb.so shadow nullok
account required /lib/security/pam_pwdb.so
session required /lib/security/pam_pwdb.so
I restarted xinetd daemon and FTP works again. My question is...Why we have to suffer this kind of problems when we are paying money to use a panel? Is not the first time, and won't be the last. And of course, the worst of all, I didn't find the solution in this forum but another. Cmon!!!
