    CentOS2Alma discussion
HELP need dev tools llke g++ installed
T
turbanator
Someone plese help.
I'm looking for a proper rpm for dev tools like g++.
Yes I'm a newbie.
system:
AMD 64 (i686 or i386 fine I guess)
FC6
plesk 8.1.1
TIA
tried that
I tried yum search g++ and it didn't come up with anything.
shortcut:
yum groupinstall "Development Tools"
Also check out mock, which I believe is only available on FC6 and above. This is what I use at ART to build packages for multiple platforms at once. It takes care of build dependency resolution automatically.
thank you
Thank you both. that gave me what I needed as well as good info to learn.
