1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
  2. Dear Pleskians, please read this carefully! New attachments and other rules Thank you!
    Dismiss Notice
  3. Dear Pleskians, I really hope that you will share your opinion in this Special topic for chatter about Plesk in the Clouds. Thank you!
    Dismiss Notice
how do ı add plesk 8.3 running x64 system to expand 2.2
Discussion in 'Plesk Expand 2.2 Troubleshooting Issues' started by silent_scream, Jan 15, 2008.
  1. silent_scream
    silent_scream Guest
    hi ;
    I want to add my plesk 8.3 server (windows x64 ) to expand 2.2, on registering its return this error;
    "<errtext>[XML] Cannot parse packet - invalid XML or DOM error. Error at file 'xmlPacket', line 2, column 18151: Datatype error: Type:InvalidDatatypeValueException, Message:Value '' is not encoded in Base64 ..</errtext>
  2. girin
    girin Guest
    Hi!
    Seems your Plesk server tries to send a license in wrong format to the Expand server.
    Try to execute the following command and give the result.
    Code:
    # /usr/local/expand/sbin/pamon host -ip <IP> -pass <PASS> << EOF
    <?xml version="1.0" encoding="UTF-8"?>
    <packet version="1.4.2.0">
      <server>
        <get>
          <key/>
        </get>
      </server>
    </packet>
    EOF
    Do not forget to change <IP> and <PASS> for real values.
  3. silent_scream
    silent_scream Guest
    when I run /usr/local/expand/sbin/pamon -ip <mypleskserverip> -pass <mypleskpass>
    no result its freeze...
  4. girin
    girin Guest
    Do you run exactly /usr/local/expand/sbin/pamon -ip <mypleskserverip> -pass <mypleskpass>? Without host option, << EOF and other lines?
    Another way:
    1. Create a file input.xml with the xml packet:
    Code:
      <server>
        <get>
          <key/>
        </get>
      </server>
    </packet>
    2. run
    Code:
    #/usr/local/expand/sbin/pamon host -ip <mypleskserverip> -pass <mypleskpass> < input.xml
  5. silent_scream
    silent_scream Guest
    this is result
    <?xml version="1.0"?>
    <packet version="1.4.2.0"><server><get><result><status>ok</status><key><plesk_ke y_id>PLSK.00168488.0009</plesk_key_id><product_version>8.1</product_version><lim _date>2008-06-20</lim_date><license_update_date>20080610</license_update_date><l im_slaves>10</lim_slaves><lim_cl>0</lim_cl><lim_dom>0</lim_dom><lim_mn>0</lim_mn ><lim_wu>0</lim_wu><MLS>99</MLS><MPCID>MyPlesk.com</MPCID><noMPC>0</noMPC><noMng MPC>0</noMngMPC><key_vz>0</key_vz><key_mssql>1</key_mssql><key_tomcat>1</key_tom cat><key_gch>1</key_gch><key_shell>1</key_shell><key_traffic>1</key_traffic><key _cl_tmpl>1</key_cl_tmpl><key_notifmgr>1</key_notifmgr><key_eventmgr>1</key_event mgr><key_actionmgr>1</key_actionmgr><key_dombackup>1</key_dombackup><key_expirat ion>1</key_expiration><key_subdomains>1</key_subdomains><key_coldfusion>1</key_c oldfusion><key_cgitory>1</key_cgitory><key_spamassassin>1</key_spamassassin><key _sitebuilder>1</key_sitebuilder><key_tts>1</key_tts><key_drweb>1</key_drweb><key _drweb_limit>30</key_drweb_limit><key_migration>1</key_migration><key_askupdate> 0</key_askupdate><key_newsfeeds>1</key_newsfeeds><reseller_email>0</reseller_ema il><store_id>1</store_id><autoinstaller_config>1</autoinstaller_config><key_dash board>1</key_dashboard><key_manage_dashboard>1</key_manage_dashboard><key_stdgui >1</key_stdgui><key_promo_virtuozzo>1</key_promo_virtuozzo><key_promo_fotolia>1< /key_promo_fotolia><product-name>0</product-name><content>PD94bWwgdmVyc2lvbj0iMS
    continued my license key....
  6. silent_scream
    silent_scream Guest
    now I added plesk to expand but when ı reload the server ;
    on reload plesk section ;
    same error
    and reload domain section;
    <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
    <packet version="2.2.2.20">
    <refresh>
    <result>
    <status>error</status>
    <errcode>2002</errcode>
    <errtext>[Transport] Temporary error occurred while processing request. Plesk server is unreachable now: Operation timed out with 0 out of -1 bytes received
    Connection log
    About to connect() to 195.149.85.xxx port 8443
    Trying 195.149.85.xxx... connected
    Connected to 195.149.85.xxx (195.149.85.xxx) port 8443
    error setting certificate verify locations, continuing anyway:
    CAfile: /usr/share/curl/curl-ca-bundle.crt
    CApath: none
    SSL re-using session ID
    SSLv3, TLS handshake, Client hello (1):</errtext>
    <server_id>15</server_id>
    </result>
    </refresh>
    </packet>
  7. Sergey L
    Sergey L Golden Pleskian Staff Member
    32
    43%
    Aug 10, 2006
    1,195
    30
    Could you please report a problem to SWsoft support service and post here a ticket ID?
    Then our engineers would be able to research the problem "online" and solve it probably.
    Server root login credentials would be required.
    The support service autoresponder might say that you have no support, but ignore it please. Since we know your ticket ID we can handle the problem.
    Thank you
  8. WaDavid
    WaDavid Guest
    Interesting, I've seen similar issues on our one expand server
Loading...
