D
DuFFBeeR
Few hours ago I've added a new domain on my Plesk, after adding this domain, httpd has stopped. I tried to start it with /etc/init.d/httpd start ... everything seems to be OK but no process still alive in process list. Then I took a look at /var/log/httpd/error_log and that's what I've got:
[Fri Sep 29 21:34:09 2006] [notice] LDAP: Built with OpenLDAP LDAP SDK
[Fri Sep 29 21:34:09 2006] [notice] LDAP: SSL support unavailable
[Fri Sep 29 21:34:09 2006] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Sep 29 21:34:10 2006] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Fri Sep 29 21:34:10 2006] [notice] Digest: generating secret for digest authentication ...
[Fri Sep 29 21:34:10 2006] [notice] Digest: done
[Fri Sep 29 21:34:10 2006] [notice] LDAP: Built with OpenLDAP LDAP SDK
[Fri Sep 29 21:34:10 2006] [notice] LDAP: SSL support unavailable
Nothing really important there ...
Then I tried to remove the domain created ... and then now Plesk is broken ! It gave me this fatal error :
ERROR: PleskFatalException
Dashboard preset used by user failed: DashboardPreset: unable to select: no such row in the table
0: /usr/local/psa/admin/plib/class.PhDomain.php:366
PhDomain->reset(integer '0', boolean true, boolean false)
1: /usr/local/psa/admin/plib/class.BsDomain.php:291
BsDomain->reset(integer '0')
2: /usr/local/psa/admin/plib/class.BsDomain.php:285
BsDomain->delete(integer '0')
3: /usr/local/psa/admin/plib/class.BsDomain.php:526
mdeleteDomains(array)
4: /usr/local/psa/admin/plib/class.Manager.php:355
Manager->removeDomains(array)
5: /usr/local/psa/admin/htdocs/domains/domains.php3:211
So I'm pretty sure httpd is not starting because of Plesk unable to create appropriate conf files related to the updated domain list. Now, how I properly delete this broken domain ? I tried to delete a domain not used for a while and everything was fine, but httpd still not working. I guest this error is related to the domain creation while the Plesk packages was updated yesterday. But now I got 47 non-working domains for a while and I don't know what to do ... PLEASE HELP ME !!!
