    CentOS2Alma discussion
installation problem of OTRS for domains
P
perler
hi,
i try to install OTRS for one domain on my plesk 7.5 server - without success.
for OTRS to work i added this to the vhost.conf of the domain
PHP:
  <Directory "/usr/share/otrs/bin/cgi-bin/">
 AllowOverride None
Options +ExecCGI -Includes
Order allow,deny
Allow from all
 </Directory>
ScriptAlias /otrs/ "/usr/share/otrs/bin/cgi-bin/"
Alias /otrs-web/ "/usr/share/otrs/var/httpd/htdocs/"
but when i call http://domain.com/otrs/installer.pl i get a
Premature end of script headers: installer.pl
in the logs. running from the shell the installer.pl seems to work.
I suspect a problem with the security settings of apache2/plesk. what could it be?
PAT
Hi PAT
here's my vhost.conf with which the installer seemed to work:
# directory settings
AllowOverride None
Order allow,deny
Allow from all
</Directory>
<Directory "/usr/share/otrs/var/httpd/htdocs/">
AllowOverride None
Order allow,deny
Allow from all
</Directory>
If it still doesn't work that way, I would check the permissions on /usr/share/otrs/bin/cgi-bin/ and /usr/share/otrs/var/httpd/htdocs/.
Hope this helps.
Cheers,
Andreas
thanks for you reply. but no success here..
which version of OTRS do you use? did you install from source or from a .deb?
PAT
I just did a 'apt-get install otrs' on my debian system. haven't tried it to build from source.
unfortunately, it's already been a while ago and I'm not using otrs anymore, so I don't know which version it was.
have you checked if the apache-user has the necessary permissions to the otrs directories?
yes www-data has wrx access, i even did a chmod 777 (and apt-get remove otrs, afterwards) ;)
i wonder where i could find some more error messages beside the dreaded "premature end of script.."..
PAT
