Plesk 6.5 Help
Thanks for you offer to help.
My email address is:
[email protected]
Alexey from SWSoft Technical Support had
returned my email with the fix shown at bottom.
He also attached several files.
I really appreciated his help
The only problem is that this did not work.
Now I get the following error when I hit the IP Aliasing button:
ifmng failed: can't set administrator rights: The pipe has been ended.
0: C:\PROGRA~1\SWsoft\Plesk\admin\plib\class.IPAddressesList.php:78 psaerror(string "ifmng failed: can't set administrator rights: The pipe has been ended.")
1: C:\PROGRA~1\SWsoft\Plesk\admin\plib\class.cList.php3:82 ipaddrlist->fetchipaddrlist()
2: C:\PROGRA~1\SWsoft\Plesk\admin\plib\class.cList.php3:98 ipaddrlist->fetchlist()
3: C:\Program Files\SWsoft\Plesk\admin\htdocs\server\ip_aliasing.php3:73 ipaddrlist->init()
====== Here is the email I received from Support ===========
Hello,
This issue will be fixed in next patch, hovewer you can do the following to fix it now:
1) stop Plesk Scheduler, Plesk Control Panel & Plesk Miscellaneous Service
2) psa-serv /uninstall
3) copy Plesk{87824292-B2FB-4722-AF4A-55170C150F72}.dll to
windows\system32 directory
4) copy nt2ux.dll, ifmng.exe, psa-serv.exe & cron.exe to admin/bin
5) psa-serv /install
6) reboot system
Run "regedit" and open:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa\Authentication Packages,
if you see: Plesk{87824292-B2FB-4722-AF4A-55170C150F72}
2) copy nt2ux.dll, ifmng.exe, psa-serv.exe & cron.exe to admin/bin
1) start Plesk Scheduler, Plesk Control Panel & Plesk Miscellaneous Service
