1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
  2. Dear Pleskians, please read this carefully! New attachments and other rules Thank you!
    Dismiss Notice
  3. Dear Pleskians, I really hope that you will share your opinion in this Special topic for chatter about Plesk in the Clouds. Thank you!
    Dismiss Notice
LEK PIN required
Discussion in 'Customer&Business Manager (formerly Plesk Billing)' started by bcdoherty, Jul 26, 2012.
  1. bcdoherty
    bcdoherty Guest
    I am in the process of setting up BM with Plesk 11... I want to set up LEK encryption but in order to set up a new PIN it requires an old PIN. Since this is the first time setting this up, I do not have an old one.
    I tried leaving it blank but it didn't like that. So I have only 2 chances left.
    I checked the help and documentation to no avail.
  2. EugeneL
    EugeneL Regular Pleskian
    20
    57%
    Feb 18, 2011
    461
    If you definitely did not enabled encryption before and you do not have credit cards in database then simply disable encryption (crear word "Agree" from "Turn on encryption" field) and save
    Then enable encryption again with you PIN
  3. bcdoherty
    bcdoherty Guest
    worked nicely. thanks.
Loading...
