• The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
Migration Manager Speed Limit Fix. min-transfer-download-speed
Status
Not open for further replies.
Minots
Hello there.
I was trying to migrate from an old and slowly server with Confixx 3 to a new one with Plesk 11.5.30 (Debian 7.3).
The old server is realy slow and i get always this message:
Code:
The minimum acceptable download speed is 1.25 MBps. The download speed between the source and destination server is 1.04 MBps.
This may increase the transfer time. For a faster transfer, please check your network connection between the source and destination servers and resolve issues (if any).
Is there any option/parameter/config i´ll be able to set a lower min-transfer-download-speed and to go forward?
Regards,
Minots
Hello,
Actually it's depend on your network port, If you want to increase it you will have do discuss this with your DC, They will assist on this
Hello,
Poorly they can´t speed up my network connection so my only option
whould be to "tell" the migration tool that it have to to the transfer
even if just 1.0 MBps is avaible. Is there anyplace i can set such a kind
of option? Maybe in .py files?
I´m willing to do the transfer manually. But I can´t find the old "PleskX.pl" anymore. :(
Does the "old methode" exists anymore?
Regards,
Minots
Thank you IgorG.
This tool seems to work nice but it told my that Rsync was not avaible at my system.
Migrating object 'web27'
Migrating object 'web28'
Migrating object 'web29'
Migrating object 'web30'
Migrating object 'web31'
Migrating object 'res0'
Migrating object 'res1'
Getting IPs
Rsync is not available on the source host
But this isn´t true. rsync is located at:
webserver053:~# locate rsync
/etc/default/rsync
/etc/init.d/rsync
/etc/rc2.d/S04rsync
/etc/rc3.d/S04rsync
/etc/rc4.d/S04rsync
/etc/rc5.d/S04rsync
/lib/modules/3.2.0-4-amd64/kernel/drivers/net/wan/farsync.ko
/lib/systemd/system/rsync.service
/opt/psa/var/apspackages/apscatalogSS8XPH.zip0e001a12-5800-17/cache/htdocs/admin/tools/owl_batch.d/jobs/parse-rsync
/opt/psa/var/apspackages/apscatalogSS8XPH.zip0e001a12-5800-17/cache/htdocs/admin/tools/owl_batch.d/jobs/parse-rsync/batch-parse-rsync.README.txt
/opt/psa/var/apspackages/apscatalogSS8XPH.zip0e001a12-5800-17/cache/htdocs/admin/tools/owl_batch.d/jobs/parse-rsync/batch-parse-rsync.php
/opt/psa/var/apspackages/apscatalogSS8XPH.zip0e001a12-5800-17/cache/htdocs/admin/tools/owl_batch.d/jobs/parse-rsync/batch-parse-rsync.sh
/usr/bin/rsync
Do you know how i can fix that?
Regards,
Minots
Try to run rsync as root on source server. Most probably this error is occurs due to sudoers restriction.
This solved my problem!
Great!
Now the Migration Manager from Panel starts correctly too!
Thank your very very much IgorG.
Regards,
Minots
Status
