P
problems
I have a recent plesk 7.5 install on a linux machine running centos.
Plesk seems to be functioning fine but qmail has not functioned properly since install.
It keeps failing and i am at a loss, all help gratefully received.
Problem 1.
A far as i can see the chkrcthosts file is not recognised, under /var/mail/plugins i do indeed find chkrcptto
If i cat the file i find a whole load of errors ie
Error: HTTPD_CONF_D not defined
Error: HTTPD_BIN_D not defined
Error: QMAIL_ROOT_D not defined
Error: QMAIL_MAILNAMES_D not defined
etc etc etc
I am sure ths is the cause of my problems and would be extremely grateful for any advice on correcting this, i did not do the install my self and im new to cmd line instruction.
Kind regards
Problem 1.
etc etc etc
Kind regards
