1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
MS SQL Problem
Discussion in 'Plesk for Windows - 8.x and Older' started by sonics, Feb 16, 2004.
  1. sonics
    sonics Regular Pleskian
    26
    23%
    Jan 4, 2004
    168
    1
    Switzerland
    Hello all
    i have a problem with the ms sql server witch plesk installed.
    it is the msde version, like you know i guess.
    now sometimes i can create a ms sql db and a user for it, and sometimes i get an "unable to conn to ms sql or db" error.
    when i look at the server part of the controlpanel and go to database, i see just a "!" and not a check. i tried allmost everthing and couldn't find out why this happen. sometimes there is a check in the server part.
    the ms sql server is running and the login is ok, so the problem is not there.
    please help me!
    i guess ddreams has a solution for it :)
  2. sonics
    26
    23%
    Jan 4, 2004
    168
    1
    Switzerland
    could any one help me with that?
    thanks chris
  3. siren@
    siren@ Guest
    Try the password setup. It should still be the default password until you change it. Plesk doesn't automatically change it as it does with MSSQL. Also, the user name should be "sa"
Loading...
