X
xtreme2490
When I install Oscommer by Plesk i get a error
sappmng: /usr/local/psa/var/cgitory/osCommerce-2.2ms2-13/scripts/postinstall execution failed: /usr/bin/htpasswd: unable to create tempoaru file 'htpasswd.tmp.bSS68w'
Unable to create file '.htpasswd'
When i afterwards want to change admin password in CP i get :
sappmng: /home/httpd/vhosts/babydagboek.be/vault_scripts/shopos/reconfigure execution failed: /usr/bin/htpasswd: unable to create temporary file 'htpasswd.tmp.0mXiPu' Unable to create file `.htpasswd`
What can i do, test this under various domains, all the same .
This is what SW Soft has to say about the issue :
It seems some permission problem with /usr/bin/htpasswd utility. We can't say exactly what can be the problem but we can't also support you because our records indicate that your free support period has expired.
Best regards,
______________________________
Dmitry Frantsev
Technical Support Engineer
SWsoft, Inc.
Can anyone help me please
Peter Mees
Best regards,
Dmitry Frantsev
SWsoft, Inc.
Peter Mees
