    CentOS2Alma discussion
PinnacleCart 3.5.2 myqsl problem
W
WaDavid
When a client tries to install this package, and the mysql server is not localhost this package fails to set up.
First problem is the config file in content/engine/engine_config.php contains the wrong hostname
Second problem is that the database does get created on the remote mysql server but without the content, thus even after fixing the config file there is still no content at all thus failing the automation part of install applications via the application vault.
Is there a patch available for this or do we wait for an update?
Installed the new one to the control panel...same problem unfortunately.
Do you have the check box checked for disallowing of applications that dont support remote mysql?
At first it was not checked but we enabled it some time after this poblem started. The interesting bit is, even after enabling that option this application still show up as installable, thus it did not take away the problem either.
