Gene Steinberg
Regular Pleskian
1. I've reported this to Parallels, but they totally screwed this up, thinking I wanted to create a subdomain labeled webmail. My real problem is that, despite correct DNS settings, since installing Plesk 10.2, the URL webmail.domainame no longer works. It just takes you to the domain's home page. I've had an three admins look it over with no solution. What changed?
2. This is a weird one. Since installing Plesk 10.2, I cannot send email from my iPhone, using AT&T's 3G network, using my server's email hostname. It just times out (cannot connect). Switching to a Wi-Fi network cures the problem. I can also use the AT&T SMTP server, but what'll happen is that the phone will go to the regular SMTP first, then after timing out, will choose the second selection. That takes several minutes for each email. And I cannot use AT&T's SMTP server except on AT&T, so it doesn't work over Wi-Fi (using my regular broadband ISP). Just switching back and forth over several accounts seems absurd.
Anyone get this?
Both AT&T and Apple are stumped, and the mail logs don't explain why the connection is failing. Remember that this capability, to send email from my iPhone on AT&T's 3G network, using my server's SMTP, worked perfectly till 10.2 was installed.
The system uses CentOS 5, kernel Linux 2.6.18-238.5.1.el5, PHP 5.2.17, MySQL 5.1.56, Apache 2.2.12-11031815. Server has 16GB RAM, using an AMD 6-core processor. But, as I said, the problem didn't occur till after the 10.2 update.
Any solutions, workarounds, etc. etc.?
Peace,
Gene
Anyone get this?
Peace,
Gene
