Hello
I would like change my Port 8443 to else i change the port in psadir/admin/conf/httpsd.conf
in Firewal i have this port active
Listen 8443 to Listen 19005
Port 8443 to Port 19005
ErrorDocument 400 https://domain.de:8443 to ErrorDocument 400 https://domain.de:19005
i restart my Plesk with /etc/init.d/psa start
and i become an error on DrWeb
If port 8443 then DrWeb start
How i can change the Port for my Plesk and DrWeb work fine?
Thanks very much
Brandmeir Gerhard
Servername:~ # /etc/init.d/psa start
xinetd off
Starting INET services. (xinetd) done
named off
Starting name server BIND 9 done
mysql off
Starting service MySQL
done
qmail on
Starting qmail: done
courier-imap on
Starting Courier-IMAP server:
Starting imapd done
Starting imap-ssl done
Starting pop3 done
Starting pop3-ssl done
postgresql off
Starting PostgreSQL done
psa-spamassassin on
Starting psa-spamassassin service: done
apache2 off
Processing config directory: /usr/local/psa/admin/conf/httpsd.*.include
/usr/local/psa/admin/bin/httpsdctl start: httpd started
Starting Plesk: done
drwebd on
Starting Dr.Web (R) daemon Dr.Web (R) daemon for Linux/Plesk Edition, version 4.32.2 (2004-11-01)
Copyright (c) Igor Daniloff, 1992-2004
Doctor Web Ltd., Moscow, Russia
Support service: http://support.drweb.com
To purchase: http://buy.drweb.com
Engine version: 4.32b
Loading /var/drweb/bases/drwtoday.vdb - Ok, virus records: 192
Loading /var/drweb/bases/drw43259.vdb - Ok, virus records: 806
Loading /var/drweb/bases/drw43258.vdb - Ok, virus records: 745
Loading /var/drweb/bases/drw43257.vdb - Ok, virus records: 720
Loading /var/drweb/bases/drw43249.vdb - Ok, virus records: 763
done
Servername:~ # Loading /var/drweb/bases/drw43248.vdb - Ok, virus records: 628
Loading /var/drweb/bases/drw43247.vdb - Ok, virus records: 652
Loading /var/drweb/bases/drw43246.vdb - Ok, virus records: 749
Loading /var/drweb/bases/drwebase.vdb - Ok, virus records: 51982
Loading /var/drweb/bases/drw43201.vdb - Ok, virus records: 364
Total virus records: 88579
Key file not found!
Plesk authorization failed: HTTP request error [7]
Error: Plesk Software not running.
xinetd off
named off
mysql off
done
qmail on
courier-imap on
Starting imapd done
Starting pop3 done
postgresql off
psa-spamassassin on
apache2 off
drwebd on
Loading /var/drweb/bases/drw43250.vdb - Ok, virus records: 858
done
Loading /var/drweb/bases/drw43202.vdb - Ok, virus records: 543
Key file not found!
Daemon is enabled for protecting 1 e-mail`s:
[email protected]
Daemon is installed, active interfaces: 127.0.0.1:3000
Thanks very much
Brandmeir Gerhard
