    CentOS2Alma discussion
Plesk 8.2 Dependency Problem
S
sonic79
SWSoft has an Dependency Problem with Plesk 8.2 on Debian 4.0.
psa_installer gives error message:
Checking whether the package dependencies are resolved.
E: Broken packages
ERROR: Unable to install packages because of package dependency problems.
Not all packages were installed.
Please, contact product technical support.
Does anybody know, when there will be a fix from swsoft ??
is it a fresh install or an update
check what apt-get install says ...
I am having the exact same problem on a brand new debian base network install
solution: install bind9
Problem occurs only if bind9 is not installed.
Dependency Problem is also mentioned in install-log
which can be found in /tmp.
Thanks for the tip. Will give it a try and report back.
