E
etoh1973
Hey, guys
server info:
Hostname ip-72-167-35-123.ip.secureserver.net
Plesk version psa v8.2.0_build82070706.15 os_FedoraCore 6
Operating system Linux 2.6.20-1.2962.fc6
I've been trying for almost 12 hours to figure out what I might be doing wrong. I installed using the psa_ autoinstaller -- Work find no issue. I login to my Plesk and to go module and I see "Sitebuilder Administration Module 4.0"
but it says this:
Could not connect to specified SiteBuilder server
I've run the sb_config:
--phpcli_path PHP CLI executable [/opt/php52/bin/php5]
--phpcgi_path PHP CGI executable [/opt/php52/cgi-bin/php5]
--update_locales Update locales [no]
--update_templates Update templates [no]
--update_modules Update modules [no]
--migrate_all Migrate all sites [no]
--help Show this help [no]
--verbose Be verbose [no]
--[no]use_rewrite Enable/disable mod_rewrite usage [yes]
--sb_admin_passwd Password for admin user [not changed by default]
--db_host MySQL database remote host [localhost]
--db_port MySQL database remote port [3306]
--db_admin_name MySQL administrator username [admin]
--db_admin_passwd MySQL administrator password xxxxxxxxxx
--sb_db_user_name SiteBuilder MySQL username [sitebuilder3]
--sb_db_user_passwd SiteBuilder MySQL password
--sb_db_name SiteBuilder database name [sitebuilder]
--httpd_port Webserver port [80]
--sb_host_ip Create virtual host on the specified IP [72.167.35.123]
--sb_hostname SiteBuilder virutal host name [ip-72-167-35-123.ip.secures
erver.net]
--httpd_owner Webserver user and group [www-data:www-data]
--[no]enable_ssl Enable/disable SSL [no]
(*did change the httpd_ownwer from apache|apache to ^^
But when attempting to connect to configure I says, can not connect to a sitebuilder server, and says .. when click on "check for local install"
Local sitebuilder installation was found but it's remote api isn't available. May be server is down or DNS is not configured properly!
-- but i do have a DNS A record setup for the name
I've tried the hostname, the sitebuilder.domainname.com but nothing and the error logs say this:
[Wed Aug 08 05:42:58 2007] [error] [client 127.0.0.1] file: /usr/local/sitebuild
er/include/Zend/Zend/Db/Adapter/Abstract.php
[Wed Aug 08 05:42:58 2007] [error] [client 127.0.0.1] line: 156
[Wed Aug 08 05:42:58 2007] [error] [client 127.0.0.1] code: 42S02
[Wed Aug 08 05:42:58 2007] [error] [client 127.0.0.1] PDOException: SQLSTATE[42S
02]: Base table or view not found: 1146 Table 'sitebuilder.config_param' doesn't
exist
Which leads to me to build that a database is not setup, but under the domain name itself is the same database name and password that was generated in the /usr/local/sitebuilder/config file.
Any insight or suggestions would be unbelievible helpfull!!
Thanks,
server info:
but it says this:
erver.net]
exist
Thanks,
