R
RobertS
(running Plesk 7.6 on windows2003)
When I try to acces using the Plesk panel a subdomain (any subdomain) I get an error, this is the error:
I cannot access these subdomain in Plesk but they do work normally. The are vissable (online) and the FTP acces works also
It is also not possible to delete them, if I do that I also got an error like this one:
on top of the panel:
then in a red marked box:
I also cannot use the performance option with normal domains(no sub-domain) anymore, when I try to open this option I get the following error:
and
I did not change anything on my server of plesk, in the event log also an error is listed, the error is:
An other error which is in the event log is the following one:
Also I get an error each night of the backup script reporting it cannot access a subdomain, this is the error:
(changed manually domainname)
The site does exist and works, in IIS al is OK, the paths are correct.
I tried the plesk reconfigurator but this tool hangs after a while, I also restarted all plesk services but this had no effect at all.
Can anyone help me?
edit:
A server reboot fixed almost al problems
Code:
Unable to create SubDomainManager object: Unable to create SubDomainPerformance object: WebServerManager::getSubDomainPerformance() failed: Unable to parse current performance.
---------------------- Debug Info -------------------------------
0: D:\SWsoft\Plesk\admin\plib\common_func.php3:153
psaerror(string 'Unable to create SubDomainManager object: Unable to create SubDomainPerformance object: WebServerManager::getSubDomainPerformance() failed: Unable to parse current performance.')
1: D:\SWsoft\Plesk\admin\htdocs\domains\subdomains\subdom_ctrl.php:39
Code:
parse error: parse error, unexpected T_STRING in D:\SWsoft\Plesk\admin\plib\class.WebServerManager.php(470) : eval()'d code on line 1
Code:
Error: Unable to create SubDomainPerformance object: WebServerManager::getSubDomainPerformance() failed: Unable to parse current performance.
Code:
Parse error: parse error, unexpected T_STRING in D:\SWsoft\Plesk\admin\plib\class.WebServerManager.php(449) : eval()'d code on line 1
Code:
The operation you were performing failed. You can retry the operation with or without changing its parameters. You may also want to report this problem to our support so that we could help you as soon as possible.
Code:
The system cannot find the path specified. (COM Error 80070003) at loadServer(17675)
at (WebServerMap::reload line 2317)
Execute file name: D:\SWsoft\Plesk\admin\bin\websrvmng.exe
Code:
Cannot modify or delete an object that was added using the COM+ Admin SDK (COM Error 8004020E, Description: De server heeft het adres van de afzender geweigerd. Reactie van server: 550 Sender is not allowed.
) at Unable to execute event
at (runtask::start line 211)
Execute file name: D:\SWsoft\Plesk\admin\bin\runtask.exe
Code:
Backup error.
Error in execute ''websrvmng' --get-subdomain-performance "--vhost-name=domain.com" "--subdomain=xri"':
The system cannot find the path specified. (COM Error 80070003) at loadServer(17675) Site xri.domain.com doesn't exist
Can anyone help me?
edit:
