1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
  2. Dear Pleskians, please read this carefully! New attachments and other rules Thank you!
    Dismiss Notice
  3. Dear Pleskians, I really hope that you will share your opinion in this Special topic for chatter about Plesk in the Clouds. Thank you!
    Dismiss Notice
Problem adding alias
Discussion in 'Plesk for Windows - 8.x and Older' started by jorfermo, Jul 26, 2005.
  1. jorfermo
    jorfermo Regular Pleskian
    26
    Jun 22, 2005
    102
    [solved] Problem adding alias
    Hi all!
    i'm trying to add an alias to an existing domain but the "add new domain alias is grayed". I'm tryng to modify the value of "Maximum number of domain aliases" under "limits" but i get this message:
    "Domain aliases: requested - 1, maximum available - 0"
    What is wrong?.
    Thanks in advance!
  2. matija
    matija Guest
    You have to check Limits for your client first, and then go to domain properties...
  3. jorfermo
    26
    Jun 22, 2005
    102
    I feel so fool.... :D
    Thank you very much, problem solved!
Loading...
