A
Alix
Problem during the installation with psa installer 3.2.1 on Debian Etch
Hello everybody,
I have a problem to install plesk. I use the autoinstaller psa_installer_v3.2.1_build070914.16_os_Debian_4.0_i386
During the installation, just after the selection of components, I get this error:
Nobody have a solution ?
Thank you
Hello everybody,
Purging configuration files for sendmail-bin ...
dpkg - warning: while removing sendmail-bin, directory `/var/run/sendmail/stampdir' not empty so not removed.
dpkg - warning: while removing sendmail-bin, directory `/var/run/sendmail/mta' not empty so not removed.
dpkg - warning: while removing sendmail-bin, directory `/var/run/sendmail' not empty so not removed.
dpkg - warning: while removing sendmail-bin, directory `/var/lib/sendmail' not empty so not removed.
dpkg - warning: while removing sendmail-bin, directory `/usr/share/doc/sendmail' not empty so not removed.
(Reading database ... 38991 files and directories currently installed.)
Unpacking psa-qmail (from .../psa-qmail_1.03-debian4.0.build82070918.10_i386.deb) ...
Checking for the system groups and users necessary for Qmail...
Checking for the group 'qmail'...
Group 'qmail' already exists
Checking for the group 'nofiles'...
Group 'nofiles' already exists
Checking for the user 'alias'...
User 'alias' already exists
Checking for the user 'qmaild'...
User 'qmaild' already exists
Checking for the user 'qmaill'...
User 'qmaill' already exists
Checking for the user 'qmailp'...
User 'qmailp' already exists
Checking for the user 'qmailq'...
User 'qmailq' already exists
Checking for the user 'qmailr'...
User 'qmailr' already exists
Checking for the user 'qmails'...
User 'qmails' already exists
Checking for the group 'popuser'...
Group 'popuser' already exists
Checking for the user 'popuser'...
ERROR: It seems there is a user with UID=110
in this system, but Plesk needs the same UID
for its operation.
Unfortunately, this situation has not yet been
resolved.
Please, visit http://www.swsoft.com/support for assistance.
Exiting...
dpkg: error processing /var/cache/apt/archives/psa-qmail_1.03-debian4.0.build82070918.10_i386.deb (--unpack):
subprocess pre-installation script returned error exit status 1
Selecting previously deselected package psa-courier-imap-add.
Unpacking psa-courier-imap-add (from .../psa-courier-imap-add_8.2.1-debian4.0.build82070918.10_i386.deb) ...
Selecting previously deselected package psa-api.
Unpacking psa-api (from .../psa-api_8.2.1-debian4.0.build82070918.10_i386.deb) ...
Selecting previously deselected package psa.
Unpacking psa (from .../psa_8.2.1-debian4.0.build82070918.10_i386.deb) ...
===> Checking for the necessary system accounts
Checking for the system groups and users necessary for MySQL...
Checking for the group 'mysql'...
Group 'mysql' already exists
Checking for the user 'mysql'...
User 'mysql' already exists
Checking for the system groups and users necessary for admin server...
Checking for the group 'psaadm'...
Group 'psaadm' already exists
Checking for the user 'psaadm'...
User 'psaadm' already exists
Checking for the group 'psaserv'...
Group 'psaserv' already exists
Trying to add supplementary group 'psaserv' for user 'www-data'... already there
Trying to add supplementary group 'psaserv' for user 'psaftp'... already there
Trying to add supplementary group 'psaserv' for user 'psaadm'... already there
Checking for the group 'psacln'...
Group 'psacln' already exists
Checking for the system groups and users necessary for Apache...
Checking for the group 'www-data'...
Group 'www-data' already exists
Checking for the user 'www-data'...
User 'www-data' already exists
Checking that /opt/psa/bin/chrootsh registered as login shell...
Selecting previously deselected package libpam-plesk.
Unpacking libpam-plesk (from .../libpam-plesk_8.2.1-debian4.0.build82070918.10_i386.deb) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
ERROR: An error occurred on attempt to install packages.
Attention! Your software might be inoperable.
Please, contact product technical support.
Thank you
