    CentOS2Alma discussion
Problem installing 7.5.2
musictus
Basic Pleskian
BIG Problem installing 7.5.2
I'm getting the following error:
Preparing for packages installation...
----- begin of output -----
Installing /PSA_7.5.2/rpm_RedHat_9/base/psa-api-common-7.5.2-rh9.build75050128.10.i586.rpm
error: Failed dependencies:
psa-api-common = 7.5.1 is needed by (installed) psa-api-cli-7.5.1-rh9.build75041216.14
also, in the Plesk Updater the date of "your release" for certain packages has become Jan 19, 2038
Moreover APACHE is no longer running!
ideas? how to go back to 7.5.1 ?
yes, i go to updater, the easy way to update your plesk and become are error wi´th this:
psa-api-common = 7.5.1 is needed by (installed) psa-api-rpc-1.3.2-3.1
but, this rpm with the version is already installed.
Any idea ???
sounds like the problem i'm having, although my dates stay correct and apache keeps working.
this is what i'm getting (additionally to being pretty frustrated currently. :/ )
Code:
Installing /PSA_7.5.2/rpm_SuSE_9.1/base/Mambo-4.5.1-7504.noarch.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/base/psa-7.5.2-suse9.1.build75050128.10.i586.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/base/psa-hotfix-7.5.2-suse9.1.build75050204.16.i586.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/base/psa-api-cli-7.5.2-suse9.1.build75050128.10.i586.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/base/psa-api-common-7.5.2-suse9.1.build75050128.10.i586.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/base/psa-courier-imap-add-7.5.2-suse9.1.build75050128.10.i586.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/base/psa-courier-imap-3.0.8-suse9.1.build75050128.10.i586.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/base/psa-key-7.5-suse9.1.build75050128.10.noarch.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/base/psa-locale-base-en-US-7.5.2-suse9.1.build75050128.10.noarch.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/opt/bu/psa-bu-7.5.2-suse9.1.build75050128.10.i586.rpm
Installing /PSA_7.5.2/rpm_SuSE_9.1/opt/docs/psa-manual-custom-skin-guide-7.5.2-suse9.1.build75050128.10.i586.rpm
----- end of output -----
May be you need to try to install it from rpms?
I used this command
cd ../rpm_FedoraCore_2/base
rpm -Uhv * ../opt/bu/* ../opt/api/*
and everything works fine.:rolleyes:
i don't have an api directory there, but added the others, basically to install everything plesk should have auto-installed:
Code:
mooputer:~/psa/PSA_7.5.2/rpm_SuSE_9.1/base # rpm -Uhv * ../opt/bu/* ../opt/docs/* ../opt/vault/*error: Failed dependencies:
the manual update worked from 7.5.0 to 7.5.1. :/
i could add the -nodeps option - but i'm not exactly sure how safe this would be.
hm..it's weird..did you download rpms by yourself or autoinstaller did it?
You may download all rpms from ftp://download1.sw-soft.com
Also there you may find release notes for this varsion..In fact these packages are not required for Plesk to function properly.
