1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
  2. Dear Pleskians, please read this carefully! New attachments and other rules Thank you!
    Dismiss Notice
  3. Dear Pleskians, I really hope that you will share your opinion in this Special topic for chatter about Plesk in the Clouds. Thank you!
    Dismiss Notice
Problem installing MSP
Discussion in 'Plesk Automation' started by bdowne01, Nov 30, 2011.
Thread Status:
Not open for further replies.
  1. bdowne01
    bdowne01 New Pleskian
    13
    35%
    Nov 23, 2011
    12
    Hey guys,
    Trying to install MSP on a fresh CentOS 5.7/i386 host. Getting this error regarding Postgres midway during the install.
    Command Line:
    sh ./ms_installer.sh --login admin --password setup --admin_email bdowney@thelinuxfix.com
    Error:
    ERROR: DatabaseError ('FATAL: Ident authentication failed for user "postgres"\n',)
    Traceback (most recent call last):
    File "/root/msp_build_1_0_1/poa/POA/CentOS-5-i386/install", line 676, in ?
    main(config)
    File "/root/msp_build_1_0_1/poa/POA/CentOS-5-i386/install", line 661, in main
    doInstall(installation_props, build, ui, config)
    File "/root/msp_build_1_0_1/poa/POA/CentOS-5-i386/install", line 543, in doInstall
    phase_fun(configureAll, progress, "Configuring system")(installation_props, installDB, progress)
    File "/root/msp_build_1_0_1/poa/POA/CentOS-5-i386/install", line 165, in rv
    return fun(*args, **kwds)
    File "/root/msp_build_1_0_1/poa/POA/CentOS-5-i386/install", line 530, in configureAll
    createDB(_dbmodule, installation_props['db_hostname'], dbname, installation_props['dsn_login'])
    File "/root/msp_build_1_0_1/poa/POA/CentOS-5-i386/install", line 71, in createDB
    admin_con = _dbmodule.connect(host = db_host, user=admin_db_user, database = admin_db)
    File "/usr/lib/python2.4/site-packages/pyPgSQL/PgSQL.py", line 2210, in connect
    return Connection(connInfo, client_encoding, unicode_results)
    File "/usr/lib/python2.4/site-packages/pyPgSQL/PgSQL.py", line 2365, in __init__
    raise DatabaseError, m
    DatabaseError: FATAL: Ident authentication failed for user "postgres"
    [Wed 30 Nov 2011 08:55:26 AM PST][ERROR] Unable to install POA
  2. bdowne01
    13
    35%
    Nov 23, 2011
    12
    Please disregard... I wiped the VM, and started over and this time it installed properly. Not sure what went sideways the first time.
Thread Status:
Loading...
