    CentOS2Alma discussion
Problem when accessing Plesk
P
Panicxz
Hello,
I'm getting a weird error message just after I log into Plesk.
The error is:
The operation you were performing failed. You can retry the operation
with or without changing its parameters. You may also want to report
this problem to our support so that we could help you as soon as
possible.
Underneath the message is a 'Show Details' button. When it is clicked
on it displays the following:
Source: Microsoft JET Database EngineDescription: No value given for
one or more required parameters.
---------------------- Debug Info -------------------------------
0: plib\common_func.php3:233
com->execute(string 'select [id], [name], [displayName], ,
[status], [type], [ttl], [ttl_unit], [refresh], [refresh_unit],
[retry], [retry_unit], [expire], [expire_unit], [minimum],
[minimum_unit], [serial], [serial_format] from [dns_zone] where
[id]=384', NULL null)
1: plib\common_func.php3:233
db_query(string 'select [id], [name], [displayName], [email],
[id]=384')
2: plib\class.Table.php:189
Table->select()
3: plib\dns\DNSZone.php:49
DNSZone->DNSZone(string '384')
4: plib\common_func.php3:2929
objectMaker(string 'DNSZone', string '384')
5: plib\dns\DNSManager.php:34
DNSManager::getDNSZone(string '384')
6: plib\class.Domain.php:787
Domain->getDNSZone()
7: plib\ui\client.domain.dns.php:78
plesk__client__domain__dns->getDNSZone()
8: plib\ui_common\DNSUIPointer.php:84
DNSUIPointer->getFlavor()
9: plib\UIPointer.php:370
UIPointer->getMetaProperty(string 'adhoc-creation', boolean false)
10: plib\UIPointer.php:404
UIPointer->allowsAdHocCreation()
11: plib\UIPointer.php:957
UIPointer->validate(object of type UserDomain)
12: plib\dashboard\Dashboard.php:51
Dashboard::fetchUIPointerValidation(string '/plesk/client@1/domain@357/dns/')
13: plib\dashboard\Dashboard.php:89
Dashboard::getUIPointerValidate(string
'/plesk/client@1/domain@357/dns/', NULL null)
14: plib\dashboard\Dashboard.php:167
Dashboard::checkElement(object of type DashboardElement_shortcut,
NULL null, boolean true)
15: plib\dashboard\DashboardElement.php:305
DashboardElement->getChild(NULL null, boolean false)
16: plib\dashboard\DashboardPreset.php:127
DashboardPreset->appendPreset(object of type DashboardPreset)
17: plib\dashboard\DashboardLocation.php:37
DashboardLocation->accessItem(string 'GET', NULL null)
18: plib\UIPointer.php:529
UIPointer->access(string 'GET')
19: htdocs\plesk.php:13
[/QUOTE]
When clicking on 'Home' it displays the following:
[QUOTE]Notice: Undefined variable: uip in C:\Program
Files\SWsoft\Plesk\admin\plib\dashboard\Dashboard.php on line 51
Fatal error: Call to a member function validate() on a non-object in
C:\Program Files\SWsoft\Plesk\admin\plib\dashboard\Dashboard.php on
line 51
[/QUOTE]
We are having same error on one of our domain.
The operation you were performing failed. You can retry the operation with or without changing its parameters. You may also want to report this problem to our support so that we could help you as soon as possible.
Please help...
