• We value your experience with Plesk during 2024
    Plesk strives to perform even better in 2025. To help us improve further, please answer a few questions about your experience with Plesk Obsidian 2024.
    https://pt-research.typeform.com/to/AmZvSXkx
Problem with Apache / Plesk
NielsD
That is my errorcode:
New configuration files for the Apache web server were not created due to the errors in configuration templates: Template processing failed: file = /usr/local/psa/admin/conf/templates/default/domainVhost.php, error = Template_Exception: [Template_Variable_Domain_PhysicalHosting] Wrong variable to subsitute: maintenanceMode file: /usr/local/psa/admin/plib/Template/Processor.php line: 27 code: 0 Previous error: Template_Exception: [Template_Variable_Domain_PhysicalHosting] Wrong variable to subsitute: maintenanceMode file: /usr/local/psa/admin/plib/Template/Processor.php line: 27 code: 0 Previous error: Template_Exception: [Template_Variable_Domain_PhysicalHosting] Wrong variable to subsitute: maintenanceMode file: /usr/local/psa/admin/plib/Template/Variable/Abstract.php line: 67 code: 0. The error message containing the detailed error descriptions was sent to you by e-mail. Please resolve the issues and click here to generate broken configuration files once again or here to generate all configuration files.
But I have no idea how to fix it. Please assist me.
Run:
Code:
 /usr/local/psa/admin/sbin/httpdmng --reconfigure-all
That should give you a more detailed error and possibly with the domains causing problems ..
I tried that and it's going through without any further problem.
For me it looks like a problem caused by the new place, where the conf files are stored, since the last update to 11.5 I made yesterday. It seems, that "something" is still trying to find the php.ini i.e and the other conf files at the old location. No idea why.
Hands-on investigation could be required ...Create a ticket seeking support from the Plesk team, it's FREE if you have unlimited domains licence ..otherwise, see my signature!
i have the same Error since as i upgade to 11.5, and a unlimited Licence 11x, but i dont know my Licence Key, i dont have a Support Code.... where i find the Licence Key on my Server ?
Greetings
Moondust
*** ok, i found : grep 'key-number' /etc/sw/keys/keys/key*
Now i need to open a Ticket :)
For the record we have resolved Niels's issue and for the rest of the community, the cause and problem was:
Plesk was not properly upgraded and as such the file
Code:
/usr/local/psa/admin/conf/templates/default/domain/domainVirtualHost.php
was corrupted. We therefore had it replaced with one of our working versions and that resolved it all.
Code:
It was done quickly and smoothly. Thx for that.
I had a similar error and upgraded from 11.09 to 11.5. and at first it seemed it did not fix the problem,
I got the error "Unable to generate the web server configuration file on the host <zole-hosting.net> because of the following errors:
Template_Exception: nginx: [emerg] listen() to 000.000.000.000:80, backlog 511 failed (98: Address already in use)
nginx: configuration file /etc/nginx/nginx.conf test failed
file: /usr/local/psa/admin/plib/Template/Writer/Webserver/Abstract.php
line: 68
code: 0
Please resolve the errors in web server configuration templates and generate the file again."
But an hour later I am no longer getting the error messages.
I had to stop then restart nginx after the upgrade -- all my clients sites went to a 404!
Code:
