    CentOS2Alma discussion
Problem with the upgrade key
C
coccia.stefano
I have Plesk 7.0.3 and I have do the upgrade to 7.5 but I have when I do the RPM -Uvh for the psa-key I receive this error
[root@server base]# rpm -Uvh psa-key-7.5-fc1.build75041216.14.noarch.rpm
Preparing... ########################################### [100%]
file /usr/local/psa/tmp/psa.key from install of psa-key-7.5-fc1.build75041216.14 conflicts with file from package psa-7.0.3-fc1.build040611.14
What I must to do?
You need to ...
rpm -Uvh base/*.rpm
Rather than just installing psa-key alone you need to install the entire contents of the base directory simultaneously as above.
[root@server rpm_FedoraCore_1]# rpm -Uvh base/*.rpm
package psa-pre-keyupdate-7.5.1-fc1.build75041216.14 is already installed
package psa-proftpd-1.2.10-fc1.build75041216.14 is already installed
package psa-proftpd-xinetd-1.2.10-fc1.build75041216.14 is already installed
package psa-logrotate-3.7-fc1.build75041216.14 is already installed
package libidn-0.4.2-fc1.build75041216.14 is already installed
package psa-qmail-1.03-fc1.build75041216.14 is already installed
package courier-imap-3.0.8-fc1.build75041216.14 is already installed
package psa-courier-imap-add-7.5.1-fc1.build75041216.14 is already installed
package Mambo-4.5.1-1 is already installed
ok but the other file? Don't see psa-key psa-api and psa-75
What does...
rpm -qa | grep psa
... say? It looks like your upgrade failed. You may need to revert to 7.0.x then upgrade to 7.1.6, then to 7.5.1 instead. Does Plesk actually load, and what version does it think it is when it loads?
nothing I have download 7.1.6 and I have tryed to upgrade fro 7.0.3 but when i try to installa psa-key I received the same problem
[root@server base]# rpm -Uvh psa-key-7.1-fc1.build71041118.17.noarch.rpm
file /usr/local/psa/tmp/psa.key from install of psa-key-7.1-fc1.build71041118.17 conflicts with file from package psa-7.0.3-fc1.build040611.14
