Azurel
Silver Pleskian
I want uninstall ProFTPD ftpserver. This service is deactivated and I don't need it, because I use winscp with auth-key and passphrase to upload files.
But this is what I get from plesk
I don't understand... what is here the problem?
The following components depend on the components you are going to remove or conflict with components you are going to install:
Apache mod_perl module, Apache mod_fcgid module, Parallels Plesk Panel, Plesk Updater, PHP5 support, Apache web server support, Apache mod_python module, Plesk Web hosting, Webalizer webstat
To complete the removal or installation, additionally remove the dependent or conflicting components. To cancel the removal or installation of certain components, select the corresponding option from the actions list.
