I have this error, please help me to repare
Autoinstaller 3.1.2 (build at 2007-03-21 17:57) started at (timezone CET) Thu Apr 26 15:36:34 2007
Command line args: /opt/psa/admin/bin/autoinstaller --enable-xml-output --source-type=plesk --target=/root/psa --select-release-id=PLESK_8_1_1
[email protected] --install-component=psa-autoinstaller --no-daemon
Try to find rcfile...
Autoinstaller rcfile not found.
Check hostname is sucessfull.
Opsys detected as: os_name=Linux os_vendor=Debian version=3.1 arch=i686 environment=
Final opsys (with overriding) is: os_name=Linux os_vendor=Debian version=3.1 arch=i686 environment=
repository: Get brief packages info for all sources
Checking for installed system packages...DebRepository: readSystemPackagesBrief: execute dpkg-query --show '--showformat=s:${Status}\nF:${Package}_installed.deb\nN:${Package}\nV:${Version}\nA:${Architecture}\nX:\n'| awk '/^s:install ok/,/^X:/ { print $0}'| grep -v '^s:'
done.
Download file products.inf3: 100% done.
Download file plesk.inf3: 100% done.
Download file sitebuilder.inf3: 11%..100% done.
release PLESK_8_1_1 is actual
Release SB_3_0_2 contains no any build for this OS
Select best build of PLESK_8_1_1 for current OS
First fit build is current best: PSA_8.1.1/plesk-8.1.1-deb3.1-i386.inf3
Select best build: finally choised PSA_8.1.1/plesk-8.1.1-deb3.1-i386.inf3
Download file PSA_8.1.1/plesk-8.1.1-deb3.1-i386.inf3: 100% done.
No removers section in this build.
No preferrers section in this build.
source line 'deb
http://autoinstall.plesk.com/debian/PSA_8.1.1 sarge all' is already in source list
Hit
http://security.debian.org sarge/updates/main Packages
Hit
http://security.debian.org sarge/updates/main Release
Hit
http://security.debian.org sarge/updates/contrib Packages
Hit
http://security.debian.org sarge/updates/contrib Release
Hit
http://security.debian.org sarge/updates/non-free Packages
Hit
http://security.debian.org sarge/updates/non-free Release
Hit
http://ftp.freenet.de sarge/main Packages
Hit
http://ftp.freenet.de sarge/main Release
Hit
http://ftp.freenet.de sarge/contrib Packages
Hit
http://ftp.freenet.de sarge/contrib Release
Hit
http://ftp.freenet.de sarge/non-free Packages
Hit
http://ftp.freenet.de sarge/non-free Release
Err
http://autoinstall.plesk.com PSA_7.5.3/ Packages
403 Forbidden
Ign
http://autoinstall.plesk.com PSA_7.5.3/ Release
Err
http://autoinstall.plesk.com sarge/all Packages
403 Forbidden
Ign
http://autoinstall.plesk.com sarge/all Release
Hit
Ign
Hit
http://ftp2.fr.debian.org sarge/main Packages
Hit
http://ftp2.fr.debian.org sarge/main Release
Hit
http://ftp2.fr.debian.org sarge/main Sources
Hit
Failed to fetch
http://autoinstall.plesk.com/debian/PSA_7.5.3/Packages.gz 403 Forbidden
Failed to fetch
http://autoinstall.plesk.com/debian/PSA_8.1.0/dists/sarge/all/binary-i386/Packages.gz 403 Forbidden
Reading Package Lists...
E: Some index files failed to download, they have been ignored, or old ones used instead.
Warning: there is errors in 'apt-get update'
Check for components installation status
Component base: mode upgrade, installed=1174575600, available=1177311600
Component psa-autoinstaller: mode upgrade, installed=1174496400, available=1176966000
Component asp: mode up2date, installed=0, available=0
Component mailman: mode up2date, installed=1174575600, available=1174557600
Component postgresql: mode up2date, installed=0, available=0
Component java: mode up2date, installed=1174575600, available=1174557600
Component spamassassin: mode up2date, installed=1174575600, available=1174557600
Component rblsmtpd: mode up2date, installed=1174575600, available=1174557600
Component mod_python: mode up2date, installed=0, available=0
Component ruby: mode up2date, installed=1174575600, available=1174557600
Component fcgi: mode up2date, installed=0, available=0
Component vault: mode up2date, installed=0, available=0
Component horde-comps: mode up2date, installed=1174575600, available=1174557600
Component docs: mode up2date, installed=1174575600, available=1174557600
Component backup-ded: mode upgrade, installed=1174575600, available=1175670000
Component drweb: mode up2date, installed=1174575600, available=1174557600
Component ppwse: mode up2date, installed=1174575600, available=1174557600
Component api: mode upgrade, installed=1174575600, available=1175670000
Component sshterm: mode up2date, installed=1174575600, available=1174557600
Component pmm: mode upgrade, installed=1174575600, available=1175670000
Component psa-firewall: mode up2date, installed=1174575600, available=1174557600
Component cs-gs: mode up2date, installed=1174575600, available=1174557600
Component psa-vpn: mode up2date, installed=1174575600, available=1174557600
Component battlefield: mode up2date, installed=1174575600, available=1174557600
Component bf2: mode up2date, installed=1174575600, available=1174557600
Component psa-fileserver: mode up2date, installed=1174575600, available=1174557600
Component watchdog: mode up2date, installed=1174575600, available=1174557600
Component sitebuilder: mode up2date, installed=0, available=0
Component sb-publish: mode up2date, installed=0, available=0
Component cf-support: mode up2date, installed=1174575600, available=1174557600
Component atis: mode up2date, installed=0, available=0
Component miva: mode up2date, installed=1174662000, available=1174644000
Component de-DE-locale: mode up2date, installed=1174842000, available=1174824000
Component ja-JP-locale: mode up2date, installed=1174842000, available=1174824000
Component es-ES-locale: mode up2date, installed=1174842000, available=1174824000
Component ru-RU-locale: mode up2date, installed=1174842000, available=1174824000
Component fr-FR-locale: mode up2date, installed=1174842000, available=1174824000
Component it-IT-locale: mode up2date, installed=1174842000, available=1174824000
Component zh-CN-locale: mode up2date, installed=1174842000, available=1174824000
Component zh-TW-locale: mode up2date, installed=1174842000, available=1174824000
Check for components requires keyupdate
No keyupdate need for component base
KeyUpdateChecker::doCheck: no components for check key update
repository: Get full packages info for all sources
Getting packages to installation list:
Get packages to installation from selected component psa-autoinstaller
resolve packages with apt-get
apt-get say following:
Building Dependency Tree...
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
kernel-image-2.4.26-2-686: Depends: initrd-tools (>= 0.1.32woody.5) but it is not going to be installed
catch error with message: Error while resolve packages by apt
ERROR: Error while resolve packages by apt
Check SElinux status after error:
Exit with ERROR status
Plesk autoinstaller.
