D
Dr Tyler
Hello,
I am reasonably new to server administration.
Our configuration is:
CPU AuthenticAMD, AMD Athlon(TM) XP 2600+
Version psa v8.3.0_build83080131.20 os_CentOS 4.2
OS Linux 2.6.9-55.0.9.EL
We just upgraded from plesk 8.2.1 to plesk 8.3.
So far all is fine except for two problems with watchdog. The first problem is the spam assassin/watch dog bug that has been reported on this thread:
http://forum.swsoft.com/showthread.p...t=SpamAssassin
Two, I ran a watchdog security scan from the plesk control panel after upgrading. I got an error in the report saying that md5 is not known (see the excerpt below). The rootkit hunter is fine and that portion of the scan runs fine as does everything else except for the MD5 checks that do not run. Has anyone else here had the some problem or do you have some suggestions for me?
I am part of a larger team of people who administer our server, and no one else has reported any other problems since the plesk 8.3 update.
Thank-you!
Tyler
WATCHDOG log excerpt
Scanning Log:
Running updater...
Mirrorfile /usr/local/psa/var/modules/watchdog/lib/rkhunter/db/mirrors.dat rotated
Using mirror http://www.rootkit.nl/rkhunter
[DB] Mirror file : Update available
Action: Database updated (current version: 2006041300, new version 2006092302)
[DB] MD5 hashes system binaries : Up to date
[DB] Operating System information : Update available
Action: Database updated (current version: 2006051200, new version 2006093000)
[DB] MD5 blacklisted tools/binaries : Up to date
[DB] Known good program versions : Up to date
[DB] Known bad program versions : Up to date
Ready.
Rootkit Hunter 1.2.8 is running
Determining OS... Unknown
Warning: This operating system is not fully supported!
Warning: Cannot find md5_not_known
All MD5 checks will be skipped!
Thank-you!
Tyler
Scanning Log:
Running updater...
Ready.
