1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
  2. Dear Pleskians, please read this carefully! New attachments and other rules Thank you!
    Dismiss Notice
  3. Dear Pleskians, I really hope that you will share your opinion in this Special topic for chatter about Plesk in the Clouds. Thank you!
    Dismiss Notice
Problem
Discussion in 'Plesk Expand 2.2 Troubleshooting Issues' started by AeroWave, Oct 1, 2007.
  1. AeroWave
    AeroWave Guest
    Hello.
    What do with it?
    Thanks.
  2. girin
    girin Guest
    Hello.
    I got the same problem. This happens then you remove an instance of an Expand Client from Plesk server.
    I resolved the problem by manual deassigning of the instance from the Expand Client. You should deassign the instance with id 52.
Loading...
