Hi all!
So I am finally taking the plunge and have upgraded to Plesk 9.2.1, of course it hasn't gone as planned. Right now I am currently running a VDS with Go Daddy and am running Plesk 8.4. I do regular backups (nightly) and those work fine with 8.x versions. Moving from 8.4 to 9.2.1 seems a bit tricky... First off the document recommends that I upgrade my 8.4 to 8.6 but I cannot do that as I am currently use a VDS through Go Daddy. So I have a couple spare machines at home and I also have Virtual Machines running on VMware Workstation, I will get to that later. Here is what I have done so far:
1) On my source server I have created a full back as per the Backup and Restore Guide for Plesk 9.2 by running the following command:
/usr/local/psa/bin/pleskbackup all /dump.psa
2) I then SCP it to my remote server and convert the back to a format in which I can only assume Plesk 9.X uses as per the Backup and Restore Guide for Plesk 9.2
/usr/local/psa/bin/pre9-backup-convert convert -d /var/lib/psa/dumps /dump.psa
3) At this point I tried to run the restore from the command line but I fail... see next step
4) Since the command line didn't work (I know I didn't pass all the correct parameters through or so I would assume). I then tried the GUI through the web page https://serverip:8443 >> Plesk Backup Manager >> Open the XML file >> Restore with all settings... Again another error:
So with that being the error message and I know for a fact the user does not exist because I delete all existing users my question to anyone is why would I get the above error??? My admin information is similar, obviously the name is the same but the server admin preferences should not interfere with client/reseller preferences should they?
Any help would be greatly appreciated I am dieing to re-provision my VDS, install Plesk 9.2.1 and restore my settings from a backup file... NONE OF THIS can happen if I can't first prove to myself that it will work on at least one of my spare machines and/or a Virtual Machine.
I'd love some help, thanks and take care!
<?xml version="1.0"?>
<execution-result status="success"><message code="FailedClientDeployment" severity="error"><context>void plesk::ClientDeployer::deployClientData(plesk::XmlNode) const</context><file>./client_deploy.cpp</file><line>96</line><text>Failed deployment of client skrakes</text><message code="ExecCmd::ExFailed" severity="error"><context>void plesk::ExecCmd::reportError() const</context><file>ExecCmd.cpp</file><line>49</line><text>Execution of /usr/local/psa/admin/plib/api-cli/client.php --create skrakes -name <username>\ <username> -notify false -passwd -email <username>@<domainname>.com -creation-date 2006-12-24 -guid c986d508-d206-4aa7-9372-2c71a0bc03cb -owner admin failed with return code 1.
Stderr is
An error occured during client creation: Unable to set "name" argument's value ("<username>"): Client with name <username> already exists.
</text></message></message></execution-result>
