H.W.B
Regular Pleskian
Hello,
After the 19th of april my crontabs stop to work.
I didn't change anything but there are microupdates from plesk installed
I use /usr/bin/wget -O /dev/null 'http://<path>/cron.php'
I got a -: /usr/bin/wget: No such file or directory error
But when i manually enter the command everything is working ok.
This is already used for 5 Years, but stops working then.
Also other scheduled task don't run
There seems to be a problem.
Can you help me
Henk
Can you help me
Henk
