LegolasTheElf
Basic Pleskian
Hi all,
i've just made the upgrade from ver. 9.2.2 to 9.2.3 and i've seen that the server have started a mailbombing against himself :-D
what seems happening:
Our server have a name into a domain hosted by him , like hosting.domain.tld, and obviously the mailserver for that domain use addresses like [email protected], so we can't create emails like [email protected].
but from the upgrade to 9.2.3 the server want to send reports via email to the address [email protected] , that obviously doesnt' exist, and generate an error like the one pasted here above.
also obviously i haven't' found where i can change the address used into plesk
***** begin email example *****
To: [email protected]
Subject: [Tech] failure notice
X-BeenThere: [email protected]
X-Mailman-Version: 2.1.9
MIME-Version: 1.0
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Sender: [email protected]
Errors-To: [email protected]
Hi. This is the qmail-send program at hosting.domain.tld
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<[email protected]>:
--- Below this line is a copy of the message.
Return-Path: <[email protected]>
Received: (qmail 20809 invoked by uid 111); 26 Oct 2009 15:09:33 +0100
Date: 26 Oct 2009 15:03:10 +0100
Message-ID: <[email protected]>
Subject: Cron <drweb@hosting> /opt/drweb/update.pl
Content-Type: text/plain; charset=3DUTF-8
Auto-Submitted: auto-generated
X-Cron-Env: <SHELL=3D/bin/sh>
X-Cron-Env: <HOME=3D/var/drweb>
X-Cron-Env: <PATH=3D/usr/bin:/bin>
X-Cron-Env: <LOGNAME=3Ddrweb>
X-Cron-Env: <USER=3Ddrweb>
ERROR: Dr.Web (R) Updater: Unable to connect to update.msk7.drweb.com: Connection timed out !
ERROR: Dr.Web (R) Updater: Unable to connect to update.msk.drweb.com: Connection timed out !
ERROR: Dr.Web (R) Updater: Unable to connect to update.msk3.drweb.com: Connection timed out !
***** end email example *****
Obviously the second trouble is the one that the email give:
the DR.Web updater gives problem in updating himself.
but this seems a sort of "some times" problem , because in others bounced email i can read this
Received: (qmail 28505 invoked by uid 111); 26 Oct 2009 16:30:15 +0100
Date: 26 Oct 2009 16:30:15 +0100
Content-Type: text/plain; charset=UTF-8
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <HOME=/var/drweb>
X-Cron-Env: <PATH=/usr/bin:/bin>
X-Cron-Env: <LOGNAME=drweb>
X-Cron-Env: <USER=drweb>
Dr.Web (R) update details:
Update server: http://update.us1.drweb.com/unix/500
Update has begun at Mon Oct 26 16:30:02 2009
Update has finished at Mon Oct 26 16:30:15 2009
Following files has been updated:
/var/drweb/bases/dwntoday.vdb
/var/drweb/updates/dwntoday.txt
so i dont' know if this is a real problem or also, for example, a moment of full working of the drweb servers.
Someone else have the same problem?
and someone have fixed it?
how?
thanks a lot in advance to all
MIME-Version: 1.0
how?
