    CentOS2Alma discussion
Problems with /etc/apache2/conf.d/zz010_psa_httpd.conf
zeroborg
Basic Pleskian
Hi all...
I have a problem with this file:
Every time that i try to restart the Apache service,
i have a fatal error (inside OR outside PLESK).
The error says that the "Document root" must be a directory.
I edit this file, i put the correct path (old: /srv/www/vhosts/htdocs, NEW: /srv/www/vhosts/httpdocs)
and after that, everything is OK.
BUT, every now and then, the file, changes and is loosing my changes.
Please, advise me, where to make the changes, so it will take it permanently.
Thank you.
Konstantinos.
what change you are trying in this file? -/etc/apache2/conf.d/zz010_psa_httpd.conf
and what OS is on the server ?
Originally posted by zeroborg
Hi all...
Offcourse. This file is handled by Plesk, thus every change you make will be overwritten every time you make a change in Plesk.
What are you trying to do ?
Hi all.
Sorry, for not replying, but the problem i had is solved (last year).
So now, everything is OK.
Thanx anyway. :)
I am getting an error while restarting the httpd service (Apache).
Error Msg is
NameVirtualHost xxx.xxx.xxx.xxx:80 has no VirtualHosts
NameVirtualHost xxx.xxx.xxx.xxx:443 has no VirtualHosts
I tried to edit the z010_psa_httpd.conf file manually. Is it because of that? Any help in this matter will be appreciated
Thanks
Mathew Sunil
After editing zz010_psa_httpd.conf Apache server is not working
When I try to restart the Httpd service I am getting the fllowing error
[warn] NameVirtualHost xxx.xxx.xxx.xxx:80 has no VirtualHosts
[warn] NameVirtualHost xxx.xxx.xxx.xxx:443 has no VirtualHosts.
I tried to do some changes in the zz010_psa_httpd.conf file. After that only this problem started. Is there any way that I can solve this problem? In fact I took a back of the zz010_psa_httpd.conf file before I editing it. Even the back up copy also not working. It is giving the same error.
Any help in this regard will be appreciated
thanks
Mathew Sunil.
Do not edit that file manually cause it will be rewritten each time you do some modification in PLESK.
One of your domain have wrong IP and this is why you get that
Try to delete the backup file, that fixed the problem for me.
It looks like every file in this folder is interpreted, so if thers is a backup file the entries are read double.
