Z
zname
I have a serious problems with Plesk 7.5.4 on Fedore Core 3. Plesk was installed on a clean FC3 server with auto install script.
Please advice with the following problems:
1. During installation Plesk couldn't start named
2. From web interface shows the following error:
ERROR
Unable to make action: Unable to manage service by dnsmng: dnsmng: Service named failed to start
0: /usr/local/psa/admin/htdocs/server/restart_services.php:28 psaerror(string "Unable to make action: Unable to manage service by dnsmng: dnsmng: Service named failed to start")
From /var/log/messages:
Aug 26 15:27:16 localhost named[9630]: starting BIND 9.2.5 -u named -c /etc/named.conf -u named -t /var/named/run-root
Aug 26 15:27:16 localhost named[9630]: using 1 CPU
Aug 26 15:27:16 localhost named[9630]: loading configuration from '/etc/named.conf'
Aug 26 15:27:16 localhost named[9630]: listening on IPv4 interface lo, 127.0.0.1#53
Aug 26 15:27:16 localhost named[9630]: listening on IPv4 interface eth0, 192.168.1.33#53
Aug 26 15:27:16 localhost named[9630]: command channel listening on 127.0.0.1#953
Aug 26 15:27:16 localhost kernel: audit(1125084436.100:0): avc: denied { read } for pid=9631 exe=/usr/sbin/named name=random dev=dm-0 ino=1504912 scontext=root:system_r:named_t tcontext=rootbject_r:named_zone_t tclass=chr_file
Aug 26 15:27:16 localhost named[9630]: could not open entropy source /dev/random: permission denied
Aug 26 15:27:16 localhost named[9630]: couldn't open pid file '/var/run/named/named.pid': Permission denied
Aug 26 15:27:16 localhost named[9630]: exiting (due to early fatal error)
Aug 26 15:27:16 localhost named: named startup failed
ERROR
