D
dwskp
Have you guys run into a problem with Tomcat when trying to deploy a war that contains other jars. I can't even get the java code to connect to mysql through mysql jars installed through the war. I have also tried placing the jars into common/libs. Still, I am getting a security related problem. For some reason tomcat is not allowing java to connect to mysql through the correcponding drivers. What do I need to do to make sure that java has access to all the jars included in the war?? I need to be able to use hibernate,struts, etc.. otherwise what is the point of having tomcat in plesk??
