1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
  2. Dear Pleskians, please read this carefully! New attachments and other rules Thank you!
    Dismiss Notice
  3. Dear Pleskians, I really hope that you will share your opinion in this Special topic for chatter about Plesk in the Clouds. Thank you!
    Dismiss Notice
Problems with webmail
Discussion in 'Plesk for Windows - 8.x and Older' started by Peter Enoch, Jun 10, 2004.
  1. Peter Enoch
    Peter Enoch Guest
    Hello
    I have just installed Plesk 6.5.2 for Windows on a Windows 2003 standard edition server. It looks like everything is working fine but webmail! ?
    If I try to connect to: http://webmail.xxx.com in a web browser i'm prompted for username and password. Here I write hch@xxx.com in the username field and the password in the password field and press OK. But i'm not allowed in, i'm prompted again for username and password!!
    POP3 and SMTP with Outlook or Outlook Express is working fine with the username and password, what is the problem??
    Please help :)
  2. MattR@
    MattR@ Guest
    The webmail only needs the e-mail prefix as the username, IE: info and not info@domain.com.
  3. Peter Enoch
    Peter Enoch Guest
    It dosn't work..
    What would be the idea of using only hch as the logon username with the webmail interface and hch@hchhimself.dk in POP3 ?
  4. MattR@
    MattR@ Guest
    To be honest, I think it's a bit of a dumb way of doing it, telling clients they must use the full login for POP3 and must only use the prefix for the Webmail but I know this is the only way it will work on our machines. Not sure what could be causing your login error.
  5. Peter Enoch
    Peter Enoch Guest
    You are running version 6.5 for windows??
    It stills says that the username and password is incorrect!
    I type hch in the username and the password in the password field...
  6. MattR@
    MattR@ Guest
    Yes I can confirm on 6.5.2 for windows to login to horde requires the prefix only IE info while POP3 Mailenable requires info@domain.com, I'm not sure why yours isn't working, it sounds like the formatting is correct,.
Loading...
