• We value your experience with Plesk during 2024
    Plesk strives to perform even better in 2025. To help us improve further, please answer a few questions about your experience with Plesk Obsidian 2024.
    https://pt-research.typeform.com/to/AmZvSXkx
psahotfix 4 problem
S
seehundnz
i tried to install the new hotfix and the matching packets via aptitude and got the following:
Code:
Selecting previously deselected package psa-hotfix4.scribed in the
(Reading database ... 56036 files and directories currently installed.)
Unpacking psa-hotfix4 (from .../psa-hotfix4_8.4.0-ubuntu6.06.build84080515.15_i386.deb) ...
Preparing to replace psa-kronolith 2.1.7-ubuntu6.06.build84080425.20 (using .../psa-kronolith_2.1.8-ubuntu6.06.build84080515.15_i386.deb) ...
Unpacking replacement psa-kronolith ...
Preparing to replace psa-qmail-rblsmtpd 0.70-ubuntu6.06.build84080425.20 (using .../psa-qmail-rblsmtpd_0.70-ubuntu6.06.build84080515.15_i386.deb) ...
Unpacking replacement psa-qmail-rblsmtpd ...
Preparing to replace psa-updates 8.4.0-ubuntu6.06.build84080425.20 (using .../psa-updates_8.4.0-ubuntu6.06.build84080515.15_all.deb) ...
Unpacking replacement psa-updates ...z# aptutude
Setting up psa-hotfix4 (8.4.0-ubuntu6.06.build84080515.15) ...
 Trying to start MySQL server...  Trying to establish test connection... connected
done
 Trying to replace files and set up right permissions...  Trying to remove old xinetd.d entries... removed `/etc/xinetd.d/smtp_psa'
removed `/etc/xinetd.d/smtps_psa'
done
 Trying to Clean up commented inetd records...  Trying to restart service xinetd... Stopping internet superserver: xinetd.
Starting internet superserver: xinetd.
done
done
Setting up psa-kronolith (2.1.8-ubuntu6.06.build84080515.15) ...
done
Setting up psa-qmail-rblsmtpd (0.70-ubuntu6.06.build84080515.15) ...
done
done
 Trying to reconfigure mail superserver records... --------- IMPORTANT INFORMATION FOR XINETD USERS ----------
The following line will be added to your /etc/inetd.conf file:
smtp stream tcp nowait.1000 root /var/qmail/bin/tcp-env tcp-env /usr/bin/env SMTPAUTH=1 END=1 /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
If you are indeed using xinetd, you will have to convert the
above into /etc/xinetd.conf format, and add it manually. See
/usr/share/doc/xinetd/README.Debian for more information.
smtps stream tcp nowait.1000 root /var/qmail/bin/tcp-env tcp-env /usr/bin/env SMTPAUTH=1 END=1 /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
mailmng: ERROR: Unable to save file '/etc/xinetd.d/smtp_psa' attributes : No such file or directory
System error 2: No such file or directory
mailmng: ERROR: Unable to save file '/etc/xinetd.d/smtps_psa' attributes : No such file or directory
 Trying to reconfigure mailnames...  Trying to restart service xinetd... Stopping internet superserver: xinetd.
done
done
 Trying to restart service xinetd... Starting internet superserver: xinetd.
done
Setting up psa-updates (8.4.0-ubuntu6.06.build84080515.15) ...
especially the
Code:
part is causing me headaches.
OS: Ubuntu 6.06 LTS on Virtuozzo as VPS
Plesk: 8.4
any ideas???
I Just found that the installer himself deletes these files:
Code:
done
but why does it try to open it then?
I had the same errors and lots of problems since with email and samba does not start
especially the
Code:
Plesk: 8.4
any ideas???
Code:
done
It is not a problem.
On Debian and Ubuntu systems /etc/inetd.conf is used by Plesk and xinetd is running in compatibility mode.
Installer removes this smtp_psa files because they are unused.
Error message itself will be fixed in Plesk 8.4.1, but such messages does not indicate real errors - it's just a garbage.
Thanks for report.
ok thanks for that, but after the installation i can't send any emails anymore, so i still do have to convert the inet.conf into xinetd format?
my smtp-service doesn't start at all. when i lokk at plesk->server->services smtp is not running and can't be started using the button.
then i checked the /etc/default/xinetd file and that seems to be correct with the -inetd_compat option set.
but still after a reboot the smtp-servcie won't run.
ok... found my mistake....... i was just too blind.
i didn't notice that the lines for smtp in inetd.conf were commented out.....
so well never mind...
