this Qmail problem sounds farmiliar
Yes, this Qmail problem sounds familiar, Maybe my past upgrade experience will help...
This is my current configuration…
Hostname
www.mydomain.com
Plesk version psa v8.1.0_build81061226.14 os_Debian 3.1
Operating system Linux 2.6.8-3-686
License key number PLSK.00000000.0002
Plesk currently indicates there 2 updates available...
New updates are available for Plesk 8.1.0, Plesk 8.1.1
...However after the grief I experienced trying to upgrade from v8.0.1 to v8.1.0 I am extremely reluctant to perform the new upgrades. I can not afford to have my server and all my clients’ domains go down again for 4 to 5 days. It is apparent from all the recent post that upgrading Plesk to v8.1.1 is plagued with similar problems. And very few solutions to problems seem to be posted here.
Perhaps, what I experienced when I upgraded to v8.0.1 will be of assistance to those having Qmail problems following the v8.1.1 upgrade. If this works please let me know…
---------------Email from Plesk FrontLine Support --------->
Hello,
> You have 'inetutils-inetd' package installed. Plesk does not support it
> natively and thus normally it should not start at all.
> But it is functional due to stale '/etc/init.d/inetd' file; because Plesk
> supports only 'netkit-inetd' and 'xinetd' packages on Debian it suppose that
> you have 'netkit-inetd' package installed:
> # ls -l /etc/init.d/inetd
> -rwxr-xr-x 1 root root 1764 2004-10-24 12:28 /etc/init.d/inetd
> # dpkg -S /etc/init.d/inetd
> netkit-inetd: /etc/init.d/inetd
> And thus Plesk tries to do '/etc/init.d/inetd restart' to manage inetd. But
> this has no sense for inetutils-inetd.
> So there are two ways to resolve your issue:
> 1) deinstall 'inetutils-inetd' package and install 'netkit-inetd' package
> back (since 'netkit-inetd' is a 'functionality' either, you may need to do it
> via 'aptitude' program);
> 2) remove stale '/etc/init.d/inetd' file and make a symbolic link to allow
> Plesk manage inetutils-inetd:
> # rm -f /etc/init.d/inetd
> # ln -s inetutils-inetd /etc/init.d/inetd
> This should help. Please decide which way you can do it and let us know if
> there is something unclear left.
<--------------- end of Email from Plesk FrontLine Support ---------
... after a few days SWsoft Tech Support logged into my server & fixed the problem, I am not exactly sure what they did but it had to do with the problem they indicated...
I hope this helps, but I am not sure if this has anything to do with the current Qmail problem, but the symthom sounds very similat. Qmail would start but would immediately stop...
If this works or if there is something different that needs to be done on this new upgrade, please let me and everyone else know...
thanks
